CBR125R 2010 Fault Code 54
Old 05-28-2017, 11:59 AM
Tom Akerman's Avatar
Question CBR125R 2010 Fault Code 54
Hi all, my bike runs fine, yet to go through the MOT, I'm sure they'll pick up on it, but from what I have found, 54 has something to do with either the rear angle sensor/circuit.
Anyone with experience with this fault code, any information on it would be a great help. I'm a new rider and this is my first bike. I'm not mechanically inept, but I'm definitely a novice.
Thanks all,
Tom
Old 05-28-2017, 12:55 PM
CaBaRet's Avatar
Hi Tom, its the Lean angle sensor, and can be checked out with a multimeter
Old 05-28-2017, 07:35 PM
Thanks, That's located near the flasher relay if I'm not mistaken?
Old 05-29-2017, 01:28 AM
CaBaRet's Avatar
Picture here Tom,turn on ignition , multimeter on volts, connect negative lead of multimeter to the green/orange wire and the positive lead of the multimeter to the white red wire, you should get a reading of between 4.75 and 5.25 volts, if not check wires from sensor back to ecu for poor connections
dwellernet
04-11-2008 04:35 AM
dwellernet
How-To: Mechanical
03-03-2008 11:36 AM
Syphen
09-19-2007 10:36 PM
z300x
02-09-2005 06:49 PM
Quick Reply: CBR125R 2010 Fault Code 54
