First Kneedown experience!
Low rpms meaning I was not in the range where all the power is. You need to be giving throttle the whole time because if you suddenly let off or give gas it can really throw the bike out of wack. For me getting the knee down gave me confidence to really lean the bike over, especially on the track. I think I should say that you really have to lean your body way off the bike at slow speeds, your *** has to be off the seat and your upper body has to be to the side of the bike, not on the gas tank. It will come with time and practice. Stay safe and be smart.
I personally hang my 1 entire cheek off the bike and my crack rests on the edge. If you are doing slow circles you will know if you need to lean off more beacause your pegs will scrap. You dont have to lean this much.
WORD OF CAUTION:
If you have all the weight on the inside peg when you scrape it - what then?
Knee should be down before the peg... otherwise you can jack the rear tire off the ground and have a very quick and unsaveable low side.
Here is my entry into corner 2. If you look under my right arm you can see the seat is empty.
If the peg can hinge up then you are probably fine... but it gets more and more risky the harder over you are and the more weight you have. On the street you might catch a bump in the road for example.
It is important NOT to support your full weight on the inside peg - if you do, then there is no way it can hinge. If it can't hinge, then it becomes a pivot point. Weight goes on it instead of the rear tire. IF you are at the edge - then that can be all it takes.
Now I have got pictures of my pegs - this is a case of do what I say, not what I do... but it is something to think about when you are riding on the edge.
