windows 2000 help
Old Oct 24, 2007 | 03:16 PM
rangerscott's Avatar
Default windows 2000 help
It's just hanging on "applying personal settings."
I tried safe mode, but no go.
Old Oct 24, 2007 | 03:17 PM
mdfirefighter's Avatar
Default RE: windows 2000 help
Logging into a domain?
Old Oct 24, 2007 | 03:44 PM
Nauree's Avatar
Upgrade to vista?
If you can't get into windows then really the next "best but not really the bestest" thing to do is to do a recovery if you have the 2000 CD. I avoid recoverys like the plague. Even if it gets you into windows you most likely to have a bunch of other things start messing up because it overwrites newer files and you'll get errors galore. If it were me I'd just reformat if windows dont load properly. Even if it only loads in Safe mode id still reformat because the time it would take to find the problem I'd be done reinstalling everything.
Old Oct 24, 2007 | 04:26 PM
Why are you still using 2000 anyway??
Old Oct 24, 2007 | 04:45 PM
rvizzle's Avatar
Start using Linux? Upgrade to XP or Vista?
Reformat?!
Old Oct 24, 2007 | 07:47 PM
Its the company computer. Just for internet and quicken books. Its got tons of malware on it, so i started deleting ****. Worked fine and even restarted a couple of times and it loaded.
Now today it doesnt want to. I finally got it in safe mode and deleted a ton with ad-aware. Still doesnt want to log on. All his business work is on the hd so we need it to run.
Xp..........Vista!!!!!!!! Hhhahahahaha. This is an ollllllldddddddddd HP pavilion. Rockin with an Athlon 850MHz and 256mb of PC100. LOL
2000 is the only windows I've never used, so I dont know any commands or get arounds.
Old Oct 24, 2007 | 08:08 PM
rvizzle's Avatar
Time to upgrade the company computer... I had an AMD Athlon 800Mhz back in 1999.. Get with the times man!
Old Oct 24, 2007 | 08:16 PM
Get ready to cringe... I've seen XP on a computer half that slow... doesn't mean you should do it.
So the answer is, put the drive in another computer and pull the data you need. Reformat and reinstall. Don't waste your time trying to figure the rest of the crap out.
Old Oct 24, 2007 | 08:46 PM
ORIGINAL: mdfirefighter
Thats probably what I'm going to do. The only thing is he doesnt have the 2000 disk. I have a copy of 98 I'm still trying to get to work on a burnt cd.
Old Oct 24, 2007 | 08:59 PM
Blue Fox's Avatar
Retired Moderator
I would upgrade to XP and not "downgrade" to Vista. If it's an older machine, Vista will drag it down to the depth's of the sea and drown it. Vista requires too much system resources to run properly than XP does.
