When a bike likes to stand up...
My F4 kinda does the same thing. I think it parts setting and part tires. Not all vehicles handle or run the same. You can go to a car lot and driver two fo the same cars and they will run and feel differant then each other. Bikes can be the same way.
get a new front tire....7-8k is usually when you should replace them anyways. funny tho, when my front tire was goin bad, the bike tended to dive into the corners real bad. kinda scared the crap outa me the first time it did it, thought i lost all the oil in my forks or messed up a spring or somethin it dove so low. but after that i got used to it and it got to be hella fun
ORIGINAL: CBRCRF
Im going to say tire pressure. Or suspension.
ORIGINAL: pitbull#1
yes i would say tire pressure too i had almost the same thing going on i took it to the dealer and they told me my tires were way below what they were supposed to be aired them up problem solved.
ORIGINAL: CBRCRF
ORIGINAL: Juliet
ok imagine your tyres are really square here ... you lean in to a bend and are riding on the "edge" of the square ... there is no support to the road towards the middle of the tyre that would be there normally if you had round tyres ..see?? ... this would effectively keep the bike over effortlessly ... it's kinda like your bike is trying to fall back onto the flattend part of the tyre .. square is bad ..it just is ..lol
Jules
Jules
ORIGINAL: MikeInCtown
Since his suspension is adjusted differently that would be the biggest difference. the tires will make the bike feel different as they are worn, but the suspension is most likely the cause. (the softer setting that your has is most likely loading the components and transferring the load and weight distribution. I'd bet that if you stiffened the front a little and moved up a few clicks on the rear that the bike will feel much different. (the harder suspension will make the bike feel lighter in the turns and the softer will make the bike feel mushy, or heavy Also, how much fuel did each bike have in it? 20 or 30 pounds can make a bike feel a lot different)
ORIGINAL: dizzie56
ORIGINAL: pitbull#1
*Again, thanks for all the responses! I REALLY appreciate them. If indeed it's tires... then I'll just have to live with the fighting... I ride on the street all the time, and though they REALLY aren't THAT squared off... I can't just pitch them and get new ones with them having PLENTY of tread left on them. I'd feel like I was just throwing money away. However... if it's suspension... then any of you suspen
I have been having issues with my F3 forks too, I'm gonna tear them down Wednesday and give them a once over. Hopefully new seals and oil will cure my issue. My old front tire was even wearing diffrentlly from one side to the other. Rh was almost gone and LH was not so bad. I was told suspension so that's where I'm going to check.
Mike - In response to your question... fuel was about the same. Both bikes showing "full", if I recall correctly. So Fuel would not be an issue. Also, when you say "moving up a few clicks"... are you talking both rebound AND dampning (top and bottom adjusters), or just one or the other? Also... on the rear... what would bumping up preload a turn or so do for me?
I believe that the softer the setup is the more the bike will feel heavier or mushier in it's travel. I want this for street riding, but for riding the curves I think that harder is better. You get a better feel with a slightly harder suspension as well. About the only thing I can come up with a comparison with is like an F-1 car. the suspension is very hard which allows the car to turn side to side quickly without rolling over. Also like sport suspension setups with corvettes or how Energy Suspension bushings make your truck turn better. (mushy suspension = slow turning ability)
I would suggest going one click up on the preload to start (which you should try based on your weight) I can't remember which direction the compression and rebound damping says is firmer, but all you need is a basic screwdriver to make small adjustments. I would firm up compression to keep the bike stiffer. Do maybe 1/4 turn increments. I'm still working on tuning my F4 shock but based on what my F2 shock felt like the newer one is like heaven. I can also tell the difference in feel with every change I make.
Of course, I could be way off base on everything I've said, but I have noticed differences on my bike based on these small changes I've made.
If a bunch of different guys reported the same thing... how could it be suspension? I assume they all have different weights from you. Probably tire pressure or need new tire(s). The front sounds bad, yeah, I know you say you don't want to replace them, tread being still good and all, but if that's the case then you really can't complain about it standing up. All the tweaking suspension in the world won't help, unless it's been a long while since you changed fork oil or if the rear shock is really old or out of adjustment.
Overall, Tires usually make the biggest difference on turn in. especially at low speeds.
I am unfamiliar with the profiles of the tires on either of the bikes, but I do know that there can be a huge difference in turning characterisitcs between tires. take a Pilot Power vs Diablo Corsa. both are excellent tires,but have 2 very different feels. The PP will lay over into a corner very easily, becuase it has a triangular profile, the DC have what it referred to as a "nuetral" turn in. the profile is very rounded. You feel this in the way the bike wants to turn in. Now, take any tire and put 7-8K miles on, and the "turn in" feel will be drastically changed. (I often have to change my front tire becuase the sides are worn well past the treadbars, but the center still looks brand new) I would not think tire pressure will play a huge part in it, unless the pressures are way off the accepted range(generally 32-38psi) anywhere in that area and I would imagine you would be ok, but I could be wrong.
Suspension adjustments will come into play, but not significantly at those low speeds. Plus, the suspension should be set up for your weight and riding style. being that more than one person rode the bike, at low speed, low probability of suspension settings. Although, you do need to set up your sag for your weight. that has to be done....period. it is very simple, and a very good thing to learn how to do. there are many, many good articles out there on how to do it, find some and read them. then take 10mins and set your sag. then the rebound needs to set based on your riding style, then after all those are set, you move on to compression for general "plushness" of the ride. ( by the way, generally preload should be used to set your sag, not how stiff your suspension is)
now, once your start putting some speed and throttle in your turns like out on the open road, then your suspension will become a major player in how the bike behaves in the corners....but thats all another story.
