what removes rust?
Well here ya go, I found this.... eh nevermind. Those are sandblasters. I've been told that there are tips for air compressors that work though. I'm sure they exist. I just can't find any right now. I've only used sandblasters.
ORIGINAL: FLYOU
did a little searching for ya. found this: http://www.theruststore.com/
Also found some homemade recipes.
Rust Remover Recipe I INGREDIENTS [ul][*]White vinegar[*]Water[/ul] PREPARATION 1. Apply undiluted white vinegar to the rust by spraying or dabbing it on (if the object is large), or by submerging the rusted object in vinegar (if the object is small). 2. Allow the vinegar to soak in for 30 minutes. Then, rinse the object off; and dry thoroughly. 3. Repeat the process, if rust remains. Rust Remover Recipe II INGREDIENTS [ul][*]Borax[*]Lemon juice[/ul] PREPARATION 1. Mix together equal parts Borax and lemon juice. 2. Apply the resulting solution to the rust by spraying or dabbing it on (if the object is large), or by submerging the object in a bath of the solution (if the object is small). 3. Allow the solution to soak in for 30 minutes. Then, rinse the object off; and dry thoroughly. 4. Repeat the process, if rust remains. Benefits of Making Your Own Rust Removers [ul][*]inexpensive[*]fast-acting[*]no harsh chemicals or fumes[/ul] Tips and Warnings 1) Objects may appear black after being soaked in vinegar or lemon juice, but should return to their original color after being rinsed in water. 2) Borax sells under the name 20 Mule Team, and can be found on the laundry aisle. 3) Keep vinegar and Borax out of the reach of children and pets 4) Do not reuse spray bottles that have contained other chemicals
good luck mang
good luck mang
thisismyaccnt is also DA MAN! thanks guys
http://www.harborfreight.com/cpi/cta...emnumber=96972
I wouldnt take it to anyone to get the rust off.. Labor is a killer man. just do that small **** urself. unless u have load of dough to throw around. I mean IMO they are only pipes.. get a wire brush for a grinder... or just steel brush and do it by hand. then spray some hi-temp paint on it and call it a day.
http://www.duplicolor.com/products/engine.html
if you send then to shop or something, after someone a$s rapes you on labor you might as well forked out some extra cash and buy a new set.
Yeah i got the hi-temp paint im just trying to get all the rust off so i dont have to worry about a layer of rust eating through my pipes/paint.
Guest
Posts: n/a
In regard to Fly's remedy ..which my misses loves
(she into every friggin home remedy yu can think of
drives me nutty with em
Grab some small rags and soak them in it then just wrap the buggers around the pipes ..
Its just like on site(in situ) soaking mate ..
then get the bloody wire brush after soaking to finish the buggers off ...
paint
done
ready in minutes ...servers three
) Grab some small rags and soak them in it then just wrap the buggers around the pipes ..
paint
done
ur welcome.
this one looks better.... *it even mentions rust* hehe
http://www.harborfreight.com/cpi/cta...emnumber=92857
If ur Tim, i'll be Al and remind you to wear ur safety glasses!!! sand + eyes = BAD. hehe but we all know that... but hey, I work in construction... and seen some things u wouldnt believe.
