Torque Wrench
With a even pull the wrench should actually click (maybe as loud as a zippo lighter opening)and you will feel the handle give a little as it breaks past the point of torque.
Test it out on a larger bolt 1/2" maybe and set it to 20lbs to get the feel for what it does when torque is met.
ORIGINAL: Nauree
Its 9lb but mine only goes as low as 10 which I didn't think would be too much of a problem. Maybe I was going too fast.
It is. When I read a specific range on a torque wrench, what ever is the lowest. I add 10 to it and thats the lowest I'll go.
For 9lbs torque you need to use a in/lbs torque wrench. Not a ft/lbs torque wrench.
If you did use an in/lbs wrench then its way off or way cheap.
Torque wrenchs (I believe) are the most accurate in the 1/4 to full range.
If you have a "click" wrench than it "gives way" when it reaches the set torque. Meaning the rachet part will stay while to handle moves a little past it.
Take it slow when torquing cuase you dont want to keep moving the bolt once it clicks. Also dont double click, it can tighten the bolt more.
ORIGINAL: rangerscott
If I ever watched someone tighten up my cylinder head and only clicked the wrench once on each bolt, I'd be pretty pissed.
For a 9lb bolt, i would have just gone somewhere cheap like Harbor Freight and bought a small one. Smallest setting I have done is 16lbs an that was the bolts on my front forks to axle.
