Sprockets interchangable between F3, F4, RR???
I was told that the sprockets for the newer bikes will fit on my F3, that the bolt pattern is the same. Is this true? I need a steel 45 tooth sprocket for a 520 chain. Thanks for any answers guys!
Hmm... that's an interesting question. I think that as long as the teeth number is the same pitch, then it's fine, but I could be totally wrong about it. Somebody want to clarify?
ORIGINAL: FFCBRf4i
Does your supplier have an application guide? Maybe try looking up the sprockets for those three models and see if they have the same part number.
I looked in the catalog at sprocketspecialists.com and it does not appear that they all interchange. F2/F3 can be the same depending on the year, RR is a different part number.
