signature banner image?
Old Oct 2, 2006 | 04:52 PM
dwhite645's Avatar
Default signature banner image?
Ok, after playing around with the feature for a while, I can't seem to make it work. But how do you get an image to show up as the signature banner at the bottom?
Old Oct 2, 2006 | 05:16 PM
Flip's Avatar
Default RE: signature banner image?
havent tried it on this board, but i assume it uses HTLM tags.
use carrots "< >" instead of paranthethis in my example:
(img src="url of the image you want")
test:
Old Oct 2, 2006 | 05:40 PM
HAVOC's Avatar
haha i hella remember that pix. i posted it up for another memeber when they were lookin to do a school report about motorcycles and helmets and etc
Old Oct 2, 2006 | 07:47 PM
VP's Avatar
VP
read the CBR Forum Help & Suggestion Center section at the bottom of the forum I had the same problem you can post questions there and administrators and the like can help
Old Oct 3, 2006 | 01:46 AM
Leveltwo's Avatar
like mine?
just insert a url from a picture hosting site, i used imageshack.us then it should come up as a pic after every post you do....btw...the url goes into the signature section on your profile, but you knew that
Old Oct 3, 2006 | 12:15 PM
dwhite645's Avatar
Well poo. I have it on putfile, and I've read the step by step instructions in the FAQ's here and still nothing. On putfile theres a URL, a BB and an HTML I believe. I also tried putting [IMG] in front and [/IMG] at the end. Still nothing. Is there a file size limit?
Old Oct 3, 2006 | 12:43 PM
rrasco's Avatar
you got an image there now, as well as a bunch of other text.
this is the code on mine:
Code:
All you need is this:
Code:
After posting there is a check box that says 'add signature' this must be checked to show your sig for that given post. there is also an option right under the signature text box in the profile that says 'Always attach signature in posts' which will do what it says.
Old Oct 4, 2006 | 12:03 AM
dwhite645's Avatar
test...
Old Oct 4, 2006 | 12:06 AM
dwhite645's Avatar
ok, test again...
Old Oct 4, 2006 | 12:15 AM
doncollins's Avatar
Retired Administrator
This is what you're trying for.....
