Riding in the rain
Old Oct 17, 2006 | 01:57 PM
voodoochyl's Avatar
Retired Moderator
Default Riding in the rain
Hey everybody. I will be picking up my motorcycle from the dealer today or tomorrow (they did a warranty service), and it has started raining. I haven't ridden in the rain yet, and I am a little intimidated. Obviously, I'll need to slow down. Does anyone have some other pointers. You guys were so helpful when it came to suggestions on riding the "superslab", and my confidence level has increased immensely. Thanks in advance.
Old Oct 17, 2006 | 02:02 PM
Paul Square's Avatar
Default RE: Riding in the rain
Stay in the tracks left by other cars if possible... don't try dragging your knees. =]
Old Oct 17, 2006 | 02:04 PM
ddvs's Avatar
Pray it doesn't happen, but when the grip on your tires start to slide while in a turn, immediately start turning wider and completely shift your weight to the other side. otherwise you risk lowsiding or highsiding. Both of which hurt your body immensely. Good luck and always ride with your hi-beams on. Might be a good idea to have your tires properly inflated as well. Remember when you first start riding engine brake more than usual so it warms your tires up faster, therefore giving you more grip.
Old Oct 17, 2006 | 02:16 PM
QuinC's Avatar
you'll be fine if you have decent tires i did a 3 hour ride in the rain/sleet and the colder it got the faster i went (within reason)... i had on a pair of pilot powers. its not bad inless you hit a puddle or some oil.
How does engine braking warm up your tires faster?
Old Oct 17, 2006 | 02:18 PM
QuinC's Avatar
ORIGINAL: Paul Square
friction
Old Oct 17, 2006 | 02:22 PM
How is more friction generated by a different braking method? I suppose that was the question I should have asked.
Old Oct 17, 2006 | 04:14 PM
CBR 600 F2's Avatar
Keep everything slow and smooth. Always allow for more braking distance, and if its raining pretty good turn your head sideways and the wind will clean off your shield. Be calm and safe.
Old Oct 17, 2006 | 05:42 PM
rrasco's Avatar
try not to lean in the turns. when i normally take a turn at a light or something, i dip it low, but when its raining i go slow enough to actually turn the handlebars to not lean the bike over. i dont like riding in the rain at all, im more paranoid than anything. too much to enjoy the ride usually.
Old Oct 17, 2006 | 06:04 PM
CBRCorey's Avatar
x2?
