Riding with a passenger?
I passed my motorcycle class and got my license last summer, but I'll be the first to admit: that class was a joke! I don't recall actually learning anything, the instructor just joked around with the students he knew, and we never once learned a single thing about riding with passengers.
I've had passengers on my enduro before, but never on pavement. My question is, what is all different when you have passengers? I know the braking distances are increased, but how much different is turning? Are there different techniques? Is it like riding a snowmobile where the passenger should lean as much as I do, or will it throw off the "gyroscope" effect?
I'm nervous because my girlfriend wants to go for a ride, but I want to make sure I'm not missing out on vital information and would like to be as safe as possible.
I tell them to lean with me. Not with the bike. (in essence keep their torso aligned with yours) Don't put their feet down when you stop. Try to warn them via a pat on the leg or whatver when you're going to accelerate and when you turn the wrist take it a little easier because the front end is more apt to come up. If you ride a bike with a real sporty riding posistion she should use the tank to help support herself and help keep some of her weight off her wrists. If it's like an F4i or one of the older 600's with a nuetral riding position then it's not that bad.
+1 on all of JP's info, but in addition to that, I would also tell your passenger to keep completely still while your driving slow or coming to a stop, even if she slides into you, tell her to not readjust herself until both your feet are on the ground. Slow speeds are the worst when it comes to passengers. Any little movement they make will upset the bike much more than if you were under way.
The worst part is when your going around a corner, and your passenger decides she wants to look over your other shoulder. Its amazing how fast your bike will stand right back up from just a bit of movement on the passengers part. Make sure she stays in the same position throughout the corner.
Make sure she fully understands everything before she gets on the back.
I read this on another forum and found it very useful.
TIPS FOR THE MOTORCYCLE PASSENGER
(Or How To Get Invited To Go Riding Again)
By Chuck Hawks
Riding on a motorcycle with a friend is one of the most fun things you can do. It can be an even more enjoyable experience if the passenger understands and follows a few simple rules. To be the kind of passenger riders want to ride with, remember the following:
1. Wear clothing that will give you some protection in the unlikely event of a spill. As a minimum, you should wear the following to protect yourself:
Footwear that protects your feet and your ankles (hiking boots are good).
Durable pants--leather is best; lacking leather, you will have to make do with jeans, work pants, or something similar.
An abrasion resistant jacket that zips or buttons up close to the neck (again, leather is best if you have it; a nylon flight jacket or parka are satisfactory, and a Levis-type jacket will do in a pinch).
Durable gloves.
Eye protection--ideally, the helmet you borrow or own should have a face shield for comfort as well as protection. If it does not, goggles are good, and glasses (dark or prescription) will do.
2. You should also attempt to dress appropriately for the weather. If you have not ridden very much, you probably do not realize how hot or how cold it can be on a motorcycle. If it is hot, it will feel a lot hotter while you are riding; if it is cold, it will feel a lot colder while you are riding. Ask the rider for advice about dressing for the anticipated conditions, but don't compromise your minimum level of protection as described above.
On hot sunny days, one trick is to wear an extra large white shirt over your jacket. It will reflect a lot of heat and help keep you cool. In general, it is easier to dress safely and comfortably for a cool day than for a hot one. Lastly, don't wear anything loose and floppy (like a long scarf or bell bottom pants) that could get caught in the rear wheel, sprockets, drive chain or belt, or any other moving part of the motorcycle. You could injure yourself, and might cause an accident.
3. Wear a securely fastened helmet that fits properly. Most riders have extra helmets and will be glad to loan you one. A helmet should be a snug fit; it should not be possible to twist it around on your head. The strap should be pulled as tight as you can get it. You can test for fit, and to see if the strap is tight, like this: grasp the chinbar of a full coverage helmet, or the edge of an open face helmet directly over your forehead, and try to pull the helmet backwards off your head. If the helmet winds up on the back of your head, tighten the strap or get a helmet that fits.
The rider can show you how to put on your helmet properly and easily (you kind of roll it onto your head from the front). If you ride often, you will eventually want to buy your own helmet. Just about any motorcycle shop can help you pick out a suitable helmet that fits you correctly.
4. Before you attempt to mount the motorcycle, make sure that the passenger footpegs are down. (They fold up when not in use, and it is easy for the rider to forget to put them down for you.) If you don't know where the footpegs are, have the rider point them out to you.
Also, beware of the hot exhaust pipes. Make sure you know where they are, and don't let your leg or any part of your body touch them as you mount or dismount the motorcycle. They can give you a severe burn right through the heaviest pants.
5. It is customary to get on or off the motorcycle from the left side. Always wait for the rider to tell you it's okay to mount or dismount. If you start to clamber on (or off) when the rider does not expect it, the sudden motion of the motorcycle will be disconcerting. You could even pull the motorcycle over, a big no-no.
6. Here is the best way to get on a motorcycle, and the method almost all passengers should use: extend your right leg over the seat, and then slide gently up onto the seat. Put your feet on the footpegs and you are onboard!
If you are not able to do that because you are a tiny person or a child, this will work: put your left foot on the left passenger foot peg, lean your body way over the motorcycle, and gently step up until you can swing your right leg over the seat and ease yourself down. You must keep your body low and lean over the motorcycle as much as possible while you get on, to help the rider keep the motorcycle balanced. The weight of your body, if it is too far out of line with the weight of the motorcycle, could pull the bike over, still a big no-no.
A person reasonably close to normal size (male or female) should not need to use this method to mount a motorcycle, and a heavy person should not attempt it under any circunstances. It is all a question of balance; the rider is not strong enough to force a big motorcycle to stay upright if you cause it to get out of balance.
To dismount, just reverse the process you used to get on. With a little practice, getting on and off will become second nature.
7. Once you are on the motorcycle, plant your feet on the passenger footpegs and keep them there. You absolutely do not want to bring your foot into contact with the rear wheel, drive chain or belt, or the hot muffler. Never attempt to help the rider hold the bike upright when it is stopped. Keep your feet safe by keeping them on the foot pegs at all times.
8. Place your hands on the rider's hips. That is the best way to hold on to the rider, and it keeps you in touch with the rider's movements. Keep your weight centered over the motorcycle. Try not to move around any more than is necessary, particularly when the motorcycle is stopped, as it affects the balance of the motorcycle.
9. Motorcycles turn by leaning (banking like an airplane), not by steering like a car. So don't be alarmed when the motorcycle leans over to go around a corner. To position yourself perfectly for a turn, just look over the rider's shoulder in the direction of the turn. If the motorcycle is turning right, look over the rider's right shoulder; if it is turning left, look over the rider's left shoulder.
You don't have to do anything else; looking naturally over the rider's inside shoulder will automatically put your weight right where it belongs in a turn. Keep your body in line with the rider's body to prevent the motorcycle from leaning more than the rider intends. (When going straight, it doesn't matter which shoulder you look over.) Never lean out of a turn; you could cause an accident that way, which is another big no-no.
10. When the rider puts on the brakes, it causes a forward weight transfer. If the rider is forced to break hard, as in an emergency, this forward weight transfer is very apparent; you will be forced against the rider, and you will start to slide forward on the seat. Don't panic. Try to keep back, away from the rider. Resist sliding forward by pressing your feet against the footpegs; use your thigh muscles to control your position on the seat.
If you slide forward, you force the rider forward, reducing the rider's control over the motorcycle. It also moves the weight distribution of the motorcycle forward, reducing the weight on the rear tire and therefore the traction of the rear tire, making it more likely that the back tire will start to skid. Obviously, none of this is desirable.
11. You can be an active participant in the ride by staying alert and being prepared. Help the rider look for potential danger, and be prepared to hang on and hold yourself back if you anticipate a need for sudden braking. Likewise, if the rider is forced to swerve the motorcycle to avoid a hazard in the road, you need to be prepared for the sudden lean and change of direction.
You can also help the rider scan for animals that may run into the road. Dogs and deer are particularly unpredictable, and you may see a deer on a hillside above the road, or a dog in somebody's front yard, before the rider. (After all, the rider is concentrating primarily on the road.) If you spot a hazard of any sort that you think the rider is unaware of, rap the rider on the appropriate shoulder, and point at the hazard in a way that brings it to the rider's attention.
Here is a link
http://www.chuckhawks.com/motorcycle_passenger_tips.htm
By Chuck Hawks
Durable gloves.
Here is a link
while the rider I have had did a good job of staying still she did move some that affected the bike. It wasn't bad, more like the wind pushing you around a little bit on a breezy day so just be prepared. I also drive slower, take turns slower, and give myself more distance between myself and the car in front on me then when I'm alone. Overall I didn't think having a rider was that bad but I also have an F2 so the seating isn't as aggressive, I outweigh her by 100 lbs and I'm 6'1" so both feet are firmly planted on the ground at a stop. Don't forget to make any adjustments for the shocks, nothing like having your headlights point up at the trees or top of cars because of the extra weight.
Some good advice given already, my bit of advice would be that riding with a pillion is a learning curve for both of you, so don't be to ambitious 1st time out.
I have seen many a rider/pillion come unstuck with the pillion dismount, just remind them not to try and dismount till you have both feet planted firmly on the ground.
