Question wiring new lights in house.
Old 02-20-2008 | 07:48 PM
DFour's Avatar
Default RE: Question wiring new lights in house.
ORIGINAL: Nauree
We're not worried about code in this thread.
[sm=smiley36.gif][sm=smiley36.gif][sm=smiley36.gif][sm=smiley36.gif]
Old 02-20-2008 | 10:10 PM
RCR's Avatar
RCR
As long as your connections are made in the box you can add wire to the original light fixture. Use indoor romex same gauge as existing and run the new wire to the track lighting your going to use (not knowing what style of track lighting cant tell how the connection is made in a box or into track fixture itself) and just buy some casing to cover up your romex and you should be good to go.
Old 02-20-2008 | 10:19 PM
sixhundredrr's Avatar
Um.... yeah.... why aren't you using a brighter light bulb or plugging in an extra lamp or something? Seems like a lot of work for something that is so easily solved.
Old 02-20-2008 | 11:39 PM
Nauree's Avatar
ORIGINAL: sixhundredrr
I am using a Halogen bulb. Still not bright enough.
Old 02-21-2008 | 12:29 AM
letsride's Avatar
What are you growing? JK Do you have an attic in this room? If so you will have to go up there find the wire to your existing light and using a junctionbox cut the wire ( after breaker has been turned off ) wire nut romex of the same guage and run it to where ever you want then you can hook up your track lighting.
Dino261
04-12-2011 10:53 AM
hparker619
08-09-2010 05:18 PM
dojomojo
07-26-2009 01:57 PM
hopkinslax12
09-16-2006 12:57 AM
Darkness_1000RR
07-14-2006 05:27 AM
Quick Reply: Question wiring new lights in house.
