popping the clucth!
Old Jul 30, 2007 | 10:11 PM
brandonrs5's Avatar
Default popping the clucth!
does anybody know if popping the clutch is bad for the bike. and how does everybody else get their wheelies up do you guys bounce and throttle hard or do you pop the clutch?
Old Jul 30, 2007 | 11:27 PM
Blue Fox's Avatar
Retired Moderator
Default RE: popping the clucth!
You might want to ask this in the stunter's section on this site........you'll get better responses there.
Old Jul 30, 2007 | 11:34 PM
D2VW14_20's Avatar
Using the clutch will affect the wear of the bike, however, some people say its nore controlled to do it that way than throttle. Usually, you'll find the engaging spot of your clutch, pull in the clutch while rolling off the throttle, and simultaniously blip the throttle back with power while releasing the clutch right before the engaging area. All this needs to be quick and controlled.
Old Jul 30, 2007 | 11:46 PM
JZHALES's Avatar
dude pull your clutch all the way in in first gear and then bounce the rpms off the rev limiter and release the clutch
Old Jul 30, 2007 | 11:51 PM
HAVOC's Avatar
ORIGINAL: JZHALES
exactly then you can call yourself a stunter .. remember if you aint clutchin it up you aint REALLY doing a wheelie
Old Jul 30, 2007 | 11:53 PM
holycrapitshassell's Avatar
ORIGINAL: JZHALES
kinda like how i release when your mom pulls me all the way in and bounces?
no wait.. its not like that at all is it?
edit:
your clutch will last you a long time as long as you're not letting it slip much, but it will wear faster than with normal riding.
Old Jul 31, 2007 | 12:23 AM
D2VW14_20's Avatar
Yup Yup Yup, if this is your first time, I would recommend getting used to what you are doing on a dirt bike or 50 or something.
Old Jul 31, 2007 | 06:41 AM
VP's Avatar
VP
Hales is right the only way to really get the clutch where you need it to be is to loosen it up a little bit... rev it to the redline, then pop it and try to lean backwards a little bit you'll do wheelies every time
Old Jul 31, 2007 | 07:59 AM
JZHALES's Avatar
lol no dude whatever you do DONT Listen to what i said youll wind up on your *** in an instant do this
get going idle speed, which means no gas your idle is pulling u along with 1 finger rdisengage the clutch as you whack the throttle all at once, just dont be like hassel and whack it too hard!
Old Jul 31, 2007 | 08:03 AM
ORIGINAL: JZHALES
lol yeah, the last thing you wanna do is yank that bad boy too hard.
