Need PC help
ORIGINAL: oreo
any program to write cd's and dVD's that allows you to save the disk image to file. that is the ISO file. Parsi primo DVD, roxio among others
The files are already on the pc. I dont need one that copies from a disk drive.
Its a game and there is files that have .001 all through .079 There is also a file with the extension sfv and that data file thing with the icon of the PC with an exclamation mark on it.
I've never had this much trouble. There's not an install file. I double checked torrent file and I have everything it listed.
You cant really make it into an ISO unless you burn it to a CD first. An ISO a copy of the physical image data on the disk. Its almost exactly like taking a drawing and putting see though paper over it and copying it. If you dont have the original then you cant make a copy. Burn the files to a CD first than create an ISO from the CD.
http://www.magiciso.com/
No 1st hand experience with it though - It's supposed to let you create, edit, burn, etc. ISO files.
Once again...
to create an ISO you must first have a CD to make the ISO from.
unless its a bin file...
http://www.magiciso.com/howto/howto....20image%20file
Again - I haven't personally used it - but I think they allow you to download a trial version.
I figured it out anyways. I had to change one of the files to let winrar open it so I could unzip the iso within.
I thought I had to make those files into an iso. Sneeky sneeky.
