MICRON PIPE
IF ANYONE CAN TELL ME WHAT KIND OF PIPE, AND WHY IT DOEN'T GET HOT I WOULD APPRECIATE IT. I BOUGHT THE BIKE WITH A FULL MICRON EXHAUST AND DON'T REALLY KNOW ALOT ABOUT IT. I KNOW THE CARBON FIBER WON'T BURN BUT I HAVEN'T SEEN ONE LIKE THIS BEFORE.
RE: MICRON PIPE
What the heck are you talking about? The gradient paint?
RE: MICRON PIPE
NO SORRY FOR THE CONFUSION, I WAS WONDER WHAT IT WAS MADE OF. IT DOESN'T GET HOT WHEN YOU RIDE
RE: MICRON PIPE
its all the packing they put inside it, i have the carbon fiber pipe and i could hold onto the pipe after a long day of riding pput then i took the packing out im lucky if i can get within an inch of it without feeling the heat
RE: MICRON PIPE
Are you sure that what you have is a FULL exhaust? looks like a slip on.
RE: MICRON PIPE
Not positive, it was on there when i bought it. I assumed it was full exhaust because it was all welded together. I have seen plenty of slip ons that were bolted, so I really don't know for sure.
RE: MICRON PIPE
Glad to see you changed your mind about caps lock! =D I don't know what it's made of but that's the same exhaust I'm going to get only silver to blue or blue to black I haven't decided yet. Now I just have to decide if I want a high mount or regular. The only thing different is the high mount allows you to lean farther to the right correct? Does the high mount get in the way of the passenger? I know you can leave the pegs on with a high mount but I don't want to have to always worry about the passenger burning themself.
Mike |
RE: MICRON PIPE
I at work and I use caps all the time, I guess it looks like i really mean the s**t when the caps are on. Yeah i like the way it changes colors this is the first one I've seen. The high mount my not work with pass pegs, I always see them with the seat cowl on so I would say negative ghost rider. If you are leaning over that far you better be on the track, thats pretty tight.
Thanks for the reply. Chad |
RE: MICRON PIPE
I believe they are made of aluminum which is pretty standard now adays. From the looks of it your system seems to be a slip on style exhaust.
