MEMTEST help. if u know what it is.
Old Feb 21, 2007 | 09:52 AM
james007torres24's Avatar
Default MEMTEST help. if u know what it is.
i just got my new ram and i did memtest and i got 6 errors. know i dont know much about ram but is this ok/allowable or should i return it???. it booted windows and games run way faster than my 512 ram.
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Old Feb 21, 2007 | 10:09 AM
telgren's Avatar
Default RE: MEMTEST help. if u know what it is.
it was never designed to even test that kind of memory running on your processor. RAM is like a light, either its on or off, broke or working. If you can play, its good.
Old Feb 21, 2007 | 11:31 AM
y not on my processor???
Old Feb 21, 2007 | 11:49 AM
mdfirefighter's Avatar
RTFM
MemTest tells me "Memory error detected...", what does this mean?
[align=left]This is not normal. Your RAM is bad, or your system is incorrectly configured. If you have overclocked your machine, or selected aggressive RAM timings in your BIOS you should try more conservative settings before judging the ram fully bad. If you can't get MemTest to run without errors even with conservative BIOS settings, your RAM is bad. Replace it, or you will experience stability and corruption problems. Correctly functioning RAM has no errors, even if you run MemTest overnight.[/align][align=left][/align][align=left]Read the manual for more details on how to determine the exact cause of the problem.[/align][align=left][/align][align=left]MDFF[/align]
Old Feb 21, 2007 | 12:26 PM
rrasco's Avatar
if its new and failing tests i would return it, wouldnt want to have to deal with that down the road once the return policy expires.
Old Feb 21, 2007 | 12:38 PM
ok thanks i will return it asap. thanks for the help.
