Mechanical and electrical question
Old Mar 1, 2008 | 12:35 AM
txsmainevent's Avatar
Default Mechanical and electrical question
First off does anyone know of a good place to buy engines online pref. a Chevy 350 LT1 for a 96 SS Impala at a reasonable price??? and second has anyone installed headrest monitors in somebodys/their own car before and can tell me a good way of running the cable from the headrest and threw the seat???? Im just having a problem running the wiring harness threw the seat and would like to know if somebody knows and tricks that would help out??
Old Mar 1, 2008 | 02:16 AM
Blue Fox's Avatar
Retired Moderator
Default RE: Mechanical and electrical question
When I replaced my engine in my Dodge Shadow, I used PowerPro engine rebuilders. I installed the new engine, and a valve spring broke about 250 miles into having the engine. This is where the company really shines. I called them up, and they sent out another motor immediately. No hassle, no sending the other one back and having to wait, NOTHING. I got the new motor in crate in about 2 days, and installed that.
NOT TO MENTION
They reimbursed me $450 for the labor to take out the blown motor and install the new one. THAT'S a company that stands behind their products and knows a thing or two about customer service.
So yes, I HIGHLY recommend PowerPro.........
http://powerpro2000.com/
As for the headsets, what type of harness do they use? Usually, they just use the yellow RCA connection, which you can run straight down through the inside of the seat.............a metal clothes hanger works great (make sure it's damn straight first.)
Old Mar 1, 2008 | 08:29 AM
Yeah it uses a single wire that breaks off at the end with 2 video connections, power and ground. My seat does not unzip anywhere and i tried the hanger thing and its a pain in the *** trying not to poke a hole out the front or back. I cant just go down threw the headrest to the bottom cuz there are only 2 slits where the lower cushion bolts to the upper cushion
Old Mar 1, 2008 | 08:36 AM
bobjoezx's Avatar
pmed you
Wranghondo
F2 Tech
Feb 19, 2012 12:57 PM
macfahad
Apr 4, 2011 10:55 PM
Cbr_BigK
Mar 1, 2011 07:02 AM
cbreric
Mar 26, 2009 07:50 AM
rwright05859
Sep 10, 2008 05:10 PM
