I want a high speed or carbon, tap & die set??
Old Jul 17, 2012 | 09:00 PM
Piranha's Avatar
Default I want a high speed or carbon, tap & die set??
I have a few projects i want to get done. It involves mostly smaller holes(metric). What (Brands) sets would you guys recommend for a Tap and Die set?? Could be a combination set too i guess...
Old Jul 19, 2012 | 06:36 PM
Piranha's Avatar
Bump. Anybody?
Old Jul 19, 2012 | 06:41 PM
estate4life's Avatar
February 2012 ROTM
I order all my taps, gages from threadcheck....
Old Jul 19, 2012 | 06:42 PM
February 2012 ROTM
info@threadcheck.com
Old Jul 19, 2012 | 09:11 PM
Piranha's Avatar
I'll check it out. Thanks man.
Old Jul 20, 2012 | 03:46 AM
sjona2011's Avatar
not sure about specific brands, but if you want them to last then dont cheap out.
Old Jul 20, 2012 | 04:23 AM
MadHattr059's Avatar
Unless you're tapping into unobtainium or something exotic, a standard HSS tap
is sufficent for the job. The key to using a tap or die is lubrication.
I prefer grease, as it will trap the chips and works better when working over-head.
However even oil will do the job. The other key, when it starts to bind, back it off a
half-turn, that will free the chips and allow the cutting surfaces to re-engage.
Unless you are setting up a machine shop, buy the taps individually, sets are a waste
of money. Pay only for the tap you need. Spend the savings on a quality tap handle,
instead and/or on extra of the correctly sized drill bits for starting the hole.
Ern
Old Jul 20, 2012 | 06:11 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
Ern
after reading many of your posts, im pretty sure we should just call you tim the tool man taylor
Old Jul 20, 2012 | 07:38 AM
sjona2011's Avatar
Ern
Do this Only when using a tap
If you do it with a die it will screw up the threads
Old Jul 20, 2012 | 09:18 AM
Conrice's Avatar
if you want to save some money, but still get a quality set - check pawn shops and used tool places.
