Got a headlight delay schematic.
Old May 23, 2008 | 06:53 PM
rangerscott's Avatar
Default Got a headlight delay schematic.
Here's the ninja 250's headlight wiring. The head light doesnt come on till the engine is started allowing the alternator to charge, which goes to a relay. The light will stay on when you hit the kill switch but will stay off the next time you turn the key to on.
Old May 23, 2008 | 09:55 PM
elmer's Avatar
Default RE: Got a headlight delay schematic.
Why?
Old May 23, 2008 | 10:54 PM
Cuase the some guys on here where trying to figure a way to cheap their HID lights off till their bikes started to they dont turn on then off, then on again when starting the bike.
Old May 29, 2008 | 09:18 AM
ffingers's Avatar
Registered Users
thanks ranger...i am going to look into this....
Old May 29, 2008 | 12:34 PM
Lamar Vannoy's Avatar
I was going to wire a switch and maybe an indicator light for when I make the switch to HID and now will look into this option too.
Old May 29, 2008 | 12:37 PM
Domin8's Avatar
tripageled has a hid delay switch that would do this right? or at least give you enough time to get the bike running before they came on ?
Old May 29, 2008 | 12:59 PM
That just gives you up to a 15 second delay. Light will come on with the bike started or not after that.
Old May 29, 2008 | 01:44 PM
MikeInCtown's Avatar
Just so I am reading this correctly, the headlight relay is what keeps the light off?
Also, what do the triangles with the lines mean? I thought I knew, but the schematic as I am reading it makes no sense in that it provides unprotected power at the same time as the relay provides fused power.[]
Old May 29, 2008 | 01:54 PM
ffingers's Avatar
Registered Users
triangles with lines are diodes....to prevent current from flowing back up the line....
i haven't really taken my time to look over this...but really the only important part for the headlights would be how the headlight relay is set up...i am going to try and figure it out...just don't have the time here at work...
Old May 29, 2008 | 02:00 PM
Thanks. I knew it was something simple, but now I'm confused as to why you would need that jumper type wire. The Alt wire and the Y/R wire pulls in the coil and completes the circuit for the headlight/10a fused circuit.
I've always been better with figuring out this stuff when seeing it in person, so that may be my confusion on this.
<edit> nevermind, I just realized that the headlight fused circuit would be what keeps the coil pulled in once the relay is activated. Duh...
