D**N!!!! Another nail in the rear tire!
Old Nov 21, 2007 | 02:18 AM
bmg velocity's Avatar
Default D**N!!!! Another nail in the rear tire!
I'm convinced I have horrid luck because in the last 7 months, now 3 sets of tires have to be replaced because of a
friggin nail in the rear tire.
That's 7 months...6 tires...since I change the fronts everytime I change the rears.
I am lucky in one respect.
I never did get a good feel for the Dunlop Qualifiers I have on now.
I'm thinking of trying the Michelin Pilots, but most likely would like Pirelli's if the local shop has them.
I need some 12/60/17 front....160/60/17 rear.
Any suggestions on models for the Pirelli's????
I spend time on this bike commuting as well as spring and summer track days
so I always look for something decently soft and grippy, but also one that won't wear out after 1.000 miles.
Thanks
Old Nov 21, 2007 | 02:34 AM
Default RE: D**N!!!! Another nail in the rear tire!
While waiting...check out this kick *** vid....
http://www.dailymotion.com/relevance...xyds3_best-of=
Old Nov 21, 2007 | 06:30 AM
isolated1523's Avatar
Retired Super Moderator
Nothin beats watchin badass bikes while listenin to Satch.
-Adam
Old Nov 21, 2007 | 09:02 AM
meanstrk's Avatar
I know it's not recommended, but I'd be patching that ****.
Old Nov 21, 2007 | 09:29 AM
MikeInCtown's Avatar
I'd be patching the tires with the nail hole and getting a dedicated set of rims and tires for track days. If you actually behave somewhat responsibly on the street you should never have a problem.
Also, WTF are you doing fronts at the same time? They wear a lot slower and yo may be able to get 50% or more wear from the front. If you buy the same tires over and over, I wouldn't worry about replacing at the same time, especially if you have that extra set for the track.
Old Nov 21, 2007 | 09:35 AM
Nauree's Avatar
Regular Diablos. Can I have your other front tires that you replaced?
Old Nov 21, 2007 | 01:32 PM
demonchild's Avatar
Pilot power 2cts. i love them
Old Nov 21, 2007 | 01:59 PM
Since I was ina bit of a rush, I simply had the local shop install the only 160/60-17 Rear tire they had in stock.
Another Dunlop Qualifier on the rear, to match the barely used front.
All for the low low price of $176...tire, labor, out the door, and it was on the bike.
I barely slithered and slided with enough air staying in my tire to make the 3 miles to the shop.
The old tire ended up having:
1 nail...
3 holes unknown by what cause holes, one of which was letting out air faster than it could be put in.
I finally took some large screws, screwed them into the leaking holes...aired it up to 55 pounds,
and limped my way to the shop.
I was in no position to bargain and shop.
It only took them one hour.
I'm back on the road at least.
Old Nov 21, 2007 | 05:11 PM
13brsxsrr's Avatar
ORIGINAL: demonchild
Hell yeah son 2CTs FTW!!!!!
Old Nov 22, 2007 | 04:22 AM
05RR's Avatar
Sorry to hear about your bad luck.
This one guy that I used to ride with went through the same thing that you did., except his bad luck all happened within a month.One day he went out and bought a new R6. On the way home he got a nail in his rear tire. He always replaces the front/rear at the same time, so, he had 2 new tires thrown on. 3 days later, same thing, nail in the rear. 2 weeks after that, same thing. What is it with the rears? You'd think that the front would be the 1st one stuck.
