Cracked block on work truck? advice
Old Feb 17, 2009 | 12:11 PM
cbrsix's Avatar
Default Cracked block on work truck? advice
I have a 98 silverado for my work truck, and it had problems heating up and the temp gauge would rise all the way to the top, then it would drop all the way back down, then climb back up to where its supposed to be but it only spits out hot air from the heat vents for a minute then it turns cold again.. I am leaking antifreeze, and I do not know where it is coming from. My temperature continues to fluctuate between normal and hot while I use it but never show signs of over heating? It doesnt seem like anything is mixing in with the oil. I pulled the dipstick and it looks clean. What should I check on this thing to get down to the problem? Thanks
Old Feb 17, 2009 | 02:06 PM
Freak*06RR's Avatar
Sounds like your thermostat is on its way out...must be sticking. Check that . Is it leaking from your overflow?
Check around your water pump also for leaks. If it is wet around the water pump there is your problem......I would also change the thermostat at the same time.
Old Feb 17, 2009 | 02:52 PM
utter05's Avatar
March 2009 ROTM
Originally Posted by Freak*06RR
Sounds like your thermostat is on its way out....
i agree start with the thermostat and if it still does it after you change that it is time to move on the the next big thing which is the water pump. it may be possible to have a blown gasket but if there is no signs of antifreeze on the block then that is ruled out.
It is good that your oil is still fine also cause that rules out a blown headgasket which is a major pain.
i think you just have a bad thermostat with a bad gasket causing the leak.
Old Feb 17, 2009 | 02:56 PM
cbrsix's Avatar
^^ Ok thanks alot I am going to check it out when I get home and let you know what I find. I will check where the wet spots are when I get home.
Old Feb 17, 2009 | 02:58 PM
DDCavi's Avatar
One thing not mentioned is a bad freeze plug. Easy fix if you can get to it.
Old Feb 17, 2009 | 03:02 PM
marc0011's Avatar
My brother had a silverado and was having this EXACT same issue. I'll get with him and see what he found.
Old Feb 17, 2009 | 03:03 PM
Freak*06RR's Avatar
If you have a blown head gasket you would know as soon as you start your car and drove it.... Big white smoke would be very noticable....not the smoke you see when your car is cold in the morning.....it would be 5x worse.
Old Feb 17, 2009 | 03:08 PM
utter05's Avatar
March 2009 ROTM
i thought about saying this as an option but you mostly can trace the leak to a freeze plug easily, as well as back to the thermostat housing. i dunno i got the flu and my mechanical thinking is not so hot right now
Old Feb 17, 2009 | 03:11 PM
DDCavi's Avatar
I figured I mention it because it doesnt seem like hes even tried to trace it other then looking at the dipstick. More options the better I guess.
Old Feb 17, 2009 | 03:13 PM
utter05's Avatar
March 2009 ROTM
Im not saying it is a bad option to check, but i do agree that he should get under the hood and take a real good look around and try to trace it down.
