Caliper help now
Old Apr 15, 2008 | 01:59 PM
RooR Mast3r904's Avatar
Default Caliper help now
Ok well now my pads arent biting but the noise is coming from where in the caliper thier is a metl bar that seems to be touching the rotor (on the very inside towards the back of the caliper it concts to the axel bolt). i think that is what is making the noise is thier any wAY TO adjust that???
Old Apr 15, 2008 | 02:05 PM
Lrn2Go's Avatar
Default RE: Caliper help now
Front or rear?
Old Apr 15, 2008 | 02:07 PM
ffingers's Avatar
Registered Users
rear....
can you take a picture...i can't visualize what part that would be....
Old Apr 15, 2008 | 02:08 PM
51plymouth's Avatar
First, less weed and more grammar. There should be NOTHING! I repeat, NOTHING--touching the rotor besides the pads...period. If anything besides the pads are touching the rotor, you need to fix that ASAP, as that is going to do bad things to either you or the bike, maybe both. Obviously, a pic of the problem area could help clarify what your writing leaves a bit cloudy...not trying to come off like a *****, but your post isn't very clear.
Old Apr 15, 2008 | 02:14 PM
Lrn2Go's Avatar
I'm still leaning towards something wasn't put together quite right when the rear wheel went back on. +1 to nothing touching the rotor besides the pads... somethin's messed up here.
Need pics!
Old Apr 15, 2008 | 02:49 PM
i took such a good pic but i cant find the cord to conect to the comp going to go look for it again
Old Apr 15, 2008 | 02:51 PM
ffingers's Avatar
Registered Users
[sm=ttiwwp.gif]
LOL...sorry had to do it!!
Old Apr 15, 2008 | 03:02 PM
ok best i can find what i circled on the other side is somthing that is right on the rotor
Old Apr 15, 2008 | 03:05 PM
ffingers's Avatar
Registered Users
oh....that is one of the caliper bolts....there is a grub screw in front of it right...meaning a flat head to take out a little screw and an allen head pin behind it...either way...something is put together VERY VERY wrong...that definitely SHOULD not be touching the rotor...i will try to find a picture of how it should be....hold on
edit...i was thinking of the wrong one..hold on, i have a picture
Old Apr 15, 2008 | 03:07 PM
yea that little metal arm is touching the rotor on the other side i took of what you are talking about and put it back on when trying to get the pads to stop touching
