Bas ?
Old May 20, 2007 | 10:10 PM
mojo's Avatar
Default Bas ?
What is a BAS ? Im having trouble starting my bike and someone said to ck my BAS>>>>>>>>>>
Old May 20, 2007 | 10:18 PM
dizzie56's Avatar
Default RE: Bas ?
Is that a pink F4i? Im thinkin its the paint job. Ur bike knows its girly lookin and it just doesnt wanna take that step out of the closed just yet.
Seriously, check into gettin a service manual and a parts manual for your bike...makes life alot easier. Give the stealership a call tomarrow morning and ask them what it is. Then use the service manual and fix it urself.
Old May 20, 2007 | 10:32 PM
mojo's Avatar
Default RE: Bas ?
Yes its white with pink lips all over and diamonds (rhinestones) all over as well. Its o.k. though shes a girl. JUS A BADDDD **** ONE ! Thanks though good idea
Old May 20, 2007 | 10:47 PM
DRam's Avatar
Very Honorable Most Senior Member :)
Default RE: Bas ?
Looks like a chick bike tome, and since its rider is a woman (check her siteprofile) that's okay.
As for checking you BAS? Ummm, Big Angry Sister? Buttered Asparagus & Sausage? We could have some fun with this. Actually I'd take a stab at Battery / Alternator / Starter. You don't describe the problem other than to say it's hard to start, but a guess is that it doesn't crank over well. That generally means a discharged battery or loose / corroded battery connections. If the battery is discharged, but, takes and holds a charge from a battery charger, and there are no loose / corroded connections,then one suspects the alternator or rectifier. If the battery ischarged and the bike doesn't crank over, one suspects the starter may be bad.
Of course, there are other reasons for hard starting, and the above is just a wild guess.
If you are so inclined a Haynes, Clymer or Honda Shop manual for your bike will provide the knowledge you need to check that all out. If you are not so inclined at trip to the shop or assistance from a knoweldgable friend is in order.
Old May 20, 2007 | 10:48 PM
kodiak1122's Avatar
Default RE: Bas ?
I believe your original post was already answered on another thread .
So... how bout some close ups on that baby.
Lets check her out.
[sm=Flahssssss.gif]
Old May 20, 2007 | 10:54 PM
mojo's Avatar
Default RE: Bas ?
Thanx guys I found out it is a Bank Angle Sensor its located above the headlite. Go n to ck it now .
Old May 20, 2007 | 10:59 PM
JZHALES's Avatar
Default RE: Bas ?
ORIGINAL: kodiak1122
Lets check her out.
[sm=Flahssssss.gif]
+1 feel free to wear a matching bikini
