airplane question
#22
I agreewith Fish. Also the use of flaps causes an even greater force. Flaps extended and down for lift. Flaps extended and up for braking andpushing down onthe wings,causing the aircraft to drop altitude, orif landing, push it down onto the tarmackkeeping it on the runway and slowing it down, (as well as reversing the turbines). The wheels are just idlers used for steering and ease of movement.
#23
#27
OK... here it is...
The AV-8 Harrier is a vectored thrust V/STOL. I actually got to see a Harrier in the flesh for a flight demo at the 1978 Confederate Air force Air Show in Harlingen, Texas. It came screaming across the sky, slowed suddenly, hovered, rotated, scooted backwards along the flightline, then sidled sideways and landed. It was incredible to see. All this was possible due to the vectored thrust model used for the Harrier. The Harrier's big Rolls Royce Pegasus engine pumps its exhaust through four nozzles that can be rotated through ninety degrees, allowing the Harrier to launch either vertically, or conventinally, or, with the nozzles at an angle, off of a sloping ramp. Once airborne, the pilot can change the angle of the nozzles to fly as a cponventional aircraft, or to hover, or, as demonstrated in the Falklands War, to aid manuevers. The only fly in the ointment is the fuel costs of vertical takeoffs, and the inability of the aircraft to sustain supersonic flight. So the fighter works primarily as ground support, and the supersonic F/A-18 takes the interceptor role for the most part.
This is from this website:
http://www.quibbles-n-bits.com/archives/engineering/
You are correct...One engine...But...four different nozzles.
![Wink](https://cbrforum.com/forum/images/smilies/wink.gif)
#28
