5 lugs, 1 wheel stud broke
Old Jun 16, 2012 | 08:05 PM
estate4life's Avatar
February 2012 ROTM
Default 5 lugs, 1 wheel stud broke
Was going to rotate my tire on a 08 Chrysler T&C....
First lug, snap off...stud broke off...so now only 4 lugs holding wheels...
It's weekend, is it okay to drive???At least til I get stud replaced...
Last edited by gotcbr; Jun 24, 2012 at 05:49 PM. Reason: satirical spelling/word removed
Old Jun 16, 2012 | 08:29 PM
Ultimeas's Avatar
Yeah 4 lugs is fine. Some cars only have 4 lugs after all. The lugnuts were stuck enough on an 08 to break the stud? Park it in a lake?
Old Jun 16, 2012 | 08:45 PM
February 2012 ROTM
Yeah, the lug was very tight and I did not have a breaker bar...tried to man it out by putting my weight on one side....felt it gave in but them shear right off....stupid me, should off find a steel pipe...but it work last time I rotate it....but then...Cheap Chrysler parts....
Old Jun 16, 2012 | 08:56 PM
74demon's Avatar
You'll be fine. I see lots of cars with 1 broken stud, everyday. Not even a problem to drive it until its convenient to fix it.
Oh, its very common with chrysler lugs....
Old Jun 16, 2012 | 09:34 PM
MadHattr059's Avatar
Wouldn't go forever, though. Note, everyone agrees it'll work for a little while.
Long term...don't blow it off. Get it replaced.
Sucky part...it's pressed in from the back. Have to do some dis-assembly to do the job.
Other advice, hit them with wd-40 when you put the lugs back on. Keeps corrosion
from binding them on your next removal.
Ern
Old Jun 16, 2012 | 10:37 PM
sjona2011's Avatar
Ern
+1 to this
dont put it off forever
whenever i rotate my tires i put an anti-seizing compound on the studs, they stay tight and makes it a breeze to get the nuts off in the future
Old Jun 16, 2012 | 10:42 PM
February 2012 ROTM
Yup, I was waiting to used up the front cheap pads and rotor, I have an extra set stock up... Was going to do it all together.... Thinking about DIY...
Old Jun 16, 2012 | 11:27 PM
Ultimeas's Avatar
Replacing a stud is usually pretty simple. The only thing you'll really need specialty tool was is a tool that you put the inside end of the new stud in, and it has a bearing on the other side. Then you just tighten a lug nut onto the stud, and it draws it into the hub.
Chryslers are notorious for this problem. Even with a breaker bar it probably would have broke. If it was truly frozen, only heat would have freed it, at the cost of your wheels.
Old Jun 17, 2012 | 12:12 AM
sjona2011's Avatar
Oh, and an impact wrench and compressor would be a good investment
Old Jun 19, 2012 | 03:14 PM
boredandstroked's Avatar
Broken studs when removing a lug nut usually means the nut was over tightened, normally by someone with an impact wrench at a shop.
Yes some cars have 4 lugs but they are spread evenly around the rim, with 4 out of 5 lugs there is a open spot with no torque on it. Its safe to drive but can cause the brake rotor to warp eventually.
