Please be gentle.....
Old Apr 10, 2006 | 05:51 AM
Behold's Avatar
Default Please be gentle.....
Hi
Im new to this forum and to bikes and just getting used to riding.
I have a 1989 CBR600F1 Hurricane and i love it.... Can't belive how much of a kick at about 7500RPM there is!!
Question tho.... HOW ON EARTH DO I WORK OUT IF IM NEARLY OUT OF FUEL!!!!! i look in but can't see whats left? is running till empty then flicking to the reserve an issue??? or will i feel the bike cutting out near the time to flick to reserve and get some more fuel???
Thanks all
Antony
Old Apr 10, 2006 | 06:46 AM
doncollins's Avatar
Retired Administrator
Default RE: Please be gentle.....
Hello and welcome to the forum.
Once you get low enough to hit reserve, you have to hit it quickly. It doesn't take much for it to die after that.
You need to start paying attention to your mileage. Find out how many miles to the gallon you get and use that. Fill up the tank and run it until you hit reserve area then fill it back up. Set the trip odometer before you do this. Then look at your receipt to compare how many miles you rode and how much fuel it took to fill back up. Divide the miles by the gallon and you'll have your MPG's.
Old Apr 10, 2006 | 07:22 AM
Behold's Avatar
Excellent guess i will be riding it till it cuts. Thanks
Old Apr 10, 2006 | 07:57 AM
CMHGUY's Avatar
you will feel the bike bogg down when you hit the gas, THATS the clue to switch to the reserve..... Then get gas as soon as possible...
And if it happens to die on you switch right away and will take a few times to start or longer than normal..... GOOD LUCK!
Old Apr 10, 2006 | 10:15 AM
josho66's Avatar
Welcome
Old Apr 10, 2006 | 11:01 AM
Behold's Avatar
Thanks josh
CMHGUY..... Just found that out!!!! couldn't turn the reserve tho its too stiff. anyway to loosen it???
What is the rough milage on reserve?
Old Apr 10, 2006 | 12:57 PM
CBRFREEK's Avatar
I had an 89 and had to hit reserver once and never went that low again.Your best bet is as mentioned...turn back your trip meter and go to say like 200 miles then fill up.
Welcome to the site.
Old Apr 10, 2006 | 01:48 PM
pitsvtec's Avatar
Hello & Welcome!!
It will die out.
Old Apr 10, 2006 | 05:59 PM
Behold's Avatar
200miles??? either im riding too hard or im having a real issue using up the petrol!!!
Old Apr 10, 2006 | 06:35 PM
JeffRR's Avatar
Ya no ****! I get about 130-150 and need some juice
