just got a cbr 1997 f3 and when you crack the throttle it dies
Old Sep 10, 2023 | 12:27 AM
12-20-1977's Avatar
Default just got a cbr 1997 f3 and when you crack the throttle it dies
Ok maybe some has had this happen. It runs good hauls butt ....when you quickly open the throttle it falls on its ***. If you roll into it and then get rpm about 3k then give it hell it revs fine . This also down in the lower revs of coures from ide and up
Old Sep 10, 2023 | 02:11 AM
dannoxyz's Avatar
Carbs are clogged and dirty. Lots of work to do proper restoration and requires lots of experience and specialised equipment (ultrasonic soaker, micro soda-blaster, etc.). Best to send to pros. Expert workmanship, reasonable fee, quick turnaround. Bike will run like brand-new off showroom floor when you get them back.
https://customcarbservices.com
Old Sep 10, 2023 | 11:34 AM
12-20-1977's Avatar
Ok thnx Iam auto mechanic so I know what the pain in that is I dont know much about bikes. Well it looks like I get to tear them all down and clean the crap out of them is there anything I need to know thats tricky or just dive right in and get to it?
Old Nov 29, 2023 | 10:15 AM
f2boi's Avatar
GO EASY ON THE LITTLE PLASTIC T PIECES BETWEEN THE CARBS/ON THE FUEL HOSE
They are old, and brittle as funk. [Atleast they are on the F2]
They are nearly impossible to replace, you'd be buying another set of carbs to steal one as far as I can tell. I broke one of them but thankfully it was before the carb and a wee plumbing T piece fits the new fuel hose and does the job. The inner T pieces that join the carb bodies won't be as easily bodged. They have to fit the carb bodies perfectly
Old Nov 29, 2023 | 10:26 AM
You will most likely need to purchase a new set of o-rings. There's a member on here, @IDoDirt who has a link to a reputable place that sells the whole kit for your bike. I've used them and can attest that the kit is great.
Old May 3, 2024 | 12:59 PM
VictoriaDi's Avatar
jackojeff
Jun 6, 2012 06:00 PM
Zergling87
Jun 30, 2010 01:21 AM
VALKYIE
Feb 14, 2008 04:21 AM
boymans
Jun 30, 2006 12:46 PM
