high idle
Old Dec 3, 2005 | 08:58 PM
philalsp's Avatar
Default high idle
I have a 2001 929rr. I just started having problems with a high idle. When I start the bike it runs ok but after a few minutes the idle should taper down but it remains at about 3000 rpm and wont go down. I think it might be in the radiator or the thermostat but I just cant figure it out. Anyone ever experience this problem?
Old Dec 4, 2005 | 12:47 AM
doncollins's Avatar
Retired Administrator
Default RE: high idle
no... but 3000 is high for any idle setting.
Old Dec 4, 2005 | 03:05 PM
pitsvtec's Avatar
I don't idle high, but to each their own.
Old Dec 4, 2005 | 04:18 PM
Anubis's Avatar
Welcome to the Boards
Old Dec 4, 2005 | 04:22 PM
L8X's Avatar
L8X
ORIGINAL: Anubis
uhh... ok... anyways, didja check to see if your (damn it, whats that thing called on older bikes that warms up your bike faster???) was on high? LOL, im sure that was no help! Damn, drugs do fry your brain... Help me out guys!
Old Dec 4, 2005 | 10:30 PM
05Tribal's Avatar
Do you mean the choke?
Old Dec 5, 2005 | 02:57 AM
mmookey's Avatar
If it has a choke or a carborator then cleaning the throttle body should solve the problem.
Old Dec 5, 2005 | 08:38 AM
doncollins's Avatar
It's FI guys.... keep trying.
Old Dec 6, 2005 | 12:34 PM
Dave929's Avatar
did you change anything from stock before it started idling high(exhaust, air filter, etc.)? Sometimes that messes with the FI, i've seen it effect the idle on an F4i.
Old Dec 6, 2005 | 01:21 PM
johndoe's Avatar
you can turn the idle down. the adjustment is on the left side (kickstand side), in the triangle shaped hole in the middle fairing. dont turn it to much or it will pop out and you will have to take the fairing off to put it back together.
