Coolant issue f4i
Old 06-23-2019, 08:52 PM
Robert Beaudry's Avatar
Default Coolant issue f4i
Hey guys I'm having a little bit of trouble with this. I got this 02 f4i off of a friend for 200 he said it was the water pump. Put one on realized afterwords that the water pump is not the issue. Run a compression test on the heads got good results. Took water pump back off and could feel the coolant run over my finger as the coolant was being poured through the radiator. Is there somewhere else that could possibly allow coolant to pour in like maybe the oil cooler or some kinda of "plug". I'm not familiar at all with liquid cooled bikes. This is my first, normally I ride my katana that I built. But I'm anxious to see how much faster fuel injection is. So please help.
Old 06-23-2019, 08:56 PM
74demon's Avatar
If the water pump is off and you're adding coolant, it will definitely come out.
What's the issue with the bike?
Old 06-24-2019, 10:41 PM
Default Problem
It has coolant in the oil. Replced water pump bcuz that's what I was told the problem was. Turns out that with the water pump out I can see it pouring into the crank case. Not through the water pump. Been doing some reading and it says its pretty common for the oil cooler seals to go out so ill try that before I do anything else
Old 06-25-2019, 12:03 AM
74demon's Avatar
Elluzion
02-23-2017 11:27 PM
ucyifly
03-31-2013 09:50 PM
CBRfenatic93
10-19-2009 09:14 PM
fbpsb82
06-24-2009 09:35 PM
Heaton830
06-02-2007 01:17 PM
Quick Reply: Coolant issue f4i
