cbr1000fj
Old Jun 2, 2014 | 11:08 AM
peter jeram's Avatar
Default cbr1000fj
Hi all,
a couple of questions. 1. sometimes the coolant just runs out of overflow, not always but often enough for me to ask, no oil traces in radiator, and engine oil is clean to. 2. can you fit any different forks to a fj without doing major engineering. many thanks in advance, as I have already had so much good advice from you guys.
Kind regards
Peter
Old Jun 2, 2014 | 11:27 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Hey Peter! To your first question, I can only assume that you have the coolant completely topped off in the radiator, correct?
If your coolant is full, and the system is good and clean, I would investigate to be certain that your thermostat is functioning properly, i.e., opening at the correct temperature - this can be done by removing it, putting it in a pan of water, and watching to see if it actuates at the appropriate temperature, if at all.
On your second question, since this is the New Member area - though you might get some feedback, you'd be better served posing the question in the Hurricane area: CBR 1000F "Hurricane" - CBR Forum - Enthusiast forums for Honda CBR Owners
Good luck with it!
Old Jun 2, 2014 | 11:32 AM
Default cbr1000fj
thank you for the help, I will try that at the weekend.
Old Jun 2, 2014 | 11:37 AM
JNSRacing's Avatar
You're welcome!
Post up a picture of your bike, if you haven't already got one somewhere on cbrforum.com.
Old Jun 2, 2014 | 11:39 AM
JNSRacing's Avatar
Nevermind! I just saw your album... looks to be in pretty good shape!
Old Jun 2, 2014 | 12:55 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
How full do you fill the reservoir? If it is above the max fill line when cold a little might run out the tube when it gets hot. My CBR does this but I make sure that the coolant never gets below the low limit line.
I think the last time I topped it off I added a bit above the max fill line. For the next few days I noticed some fluid coming out of the overflow tube when I first turned it off.
Old Jun 2, 2014 | 02:27 PM
thank you jnsracing, I`ve had her 5 years now, been a slow job getting her looking good but I think I`m winning went through mot on sat with no advisories, still a few things to do, but gives me something to do at weekends, thanks again for all your help.
Old Jun 2, 2014 | 07:20 PM
RoadiJeff's Avatar
You're welcome. WE were glad to be of help.
Old Jun 2, 2014 | 11:23 PM
stealthCBR929's Avatar
Official Glory Detailer
Hi peter welcome to the forum . Nice bike the 1000f is one of my personal favorites .
Old Jun 3, 2014 | 04:05 AM
wheelnut's Avatar
Welcome Crew
hi and welcome aboard, glad to see another mk1 owner, with regards to your question of coolant, check the pipe that goes through the cap for the overflow,mine went right down to the bottom of the tank, with the bike warm and the pipe in the coolant it dripped out the overflow,i cut mine down a couple of inches and it hasn't leaked since.
