cbr 600 f2 electrical problem
help....my son bought a cbr 600f2 about 2 months ago.(for £150,sorry had to put that in still cant believe it my self)the bike was running fine until a fortnight ago.I got the call to go and pick him up where he told me all he could smell was rotten eggs.We had a look through the forums and pined it down to a faulty regulator.When we examined it the wires has melted in the plug.A new regulator was bought the wires were trimmed and fitted to the new plug,a week later a new battery arrived,great lets get the thing running .....ignition on.dashboard lights on,a bit of choke and away we go,the engine spins but does not fire.....bollocks....i see what it is the kill switch is on the off position that will be why the engine is turning but not firing....kill switch moved to the run position ignition on dash lights up again...hit the start button ..pop..10a fuse blown...could be a faulty fuse lets try again...fuse in ...check everything is working....no headlight,will replace the bulb later.....ignition...press start button......pop.....fuse has gone again.....AAAAAAGGGGHHHHHH....Can anybody point us in the right direction as to what is going wrong.this is the first time we have used a forum so be good to us.
Which fuse keeps blowing? What component does the fuse provide protection for? Usually a blown fuse indicates a short to ground BEFORE the component or the component itself is shorted... let me know which fuse is blowing and I might be able to help u out.
its the 10amp fuse...thanks for replying
Your fuse panel cover should have descriptions telling you which fuse powers which circuits. Unfortunately I don't know what the "10 amp" fuse powers on your F2, I ride an F1 Hurricane and it has multiple 10 amp fuses for different circuits and the cover for the fuse panel tells me which fuses are which so I would think an F2 would have that aswell. I would have to agree with Boxdgm, try and find out EXACTLY which 10A fuse is blowing, that'll help alot. Good Luck.
Well, the R/R's on the whole CBR-series were poorly engineered. It is a common
complaint on an other-wise flawless platform. I'm guessing, when the r/r started
failing, it was sending poor voltage to the head-light and caused it to over-heat.
You can get a new head-light plug end at any auto store. I recommend soldering
the connection along with heat-shrink tubing. I have had good luck with the
crimp-style connectors, but I like the cleaner look the bundle has.
That should take care of the head-light, hopefully with the new r/, you'll
be good to go.
Ern
be good to go.
Ern
