Smilies
Turn on the smilies in your personal page.............??
Posting Rules
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
All seems in order ?
But what do I know.............................!
Look at the bottom of the page when you next send a message - there's a box there that disables smilies..........maybe needs to be changed.
Posting Rules
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Guest
Posts: n/a
What Pete said ,
and as well , go to your profile settings and check the box/circle that says what type of editor to use ...
set it ti use the wysiwyg full advanced editor ..
When you go to post , make sure you are in " advanced mode " then you should see some smilies on your right of the post or edit box ... at the bottom of the smilies window you will see a small link that's says " more " hit it and all the hundreds of smilies will load in a new window for you to pick from ...
Guest
Posts: n/a
What Pete said ,
When you go to post , make sure you are in " advanced mode " then you should see some smilies on your righ of the post or edit box ... at the bottom of the smilies window you will see a small link that's says " more " hit it and all the hundreds of smilies will load in a new window for you to pick from ...
BTW- when editing an existing post , you need to hit the " go advanced " button the open the full optioned editor ... :-)
on
Same subject kinda
How come my avatar an animated gif runs proper on my local drive
in my browser but when uploaded won't run just displays static
and shows a reduced file size ? It's the right spec less than 80x 80
and not big 11.4k
Same one i used since last year but dunno tried reloading it a few times
and .............nada
Any ideas drivin' me nuts
NEVER MIND RESAMPLED IT ON ONE OF THOSE ONLINE GIF SITES
AND IT RUNS NOW
and not big 11.4k
AND IT RUNS NOW
