Restricted Output (warning long post)
Old 09-07-2011, 08:09 AM
Chammyman's Avatar
So the selling point of not having to change gear is lies then?
I also missed the whoosh at 6krpm.
Can't recall the gear it was a good few days ago, my 130 vid seems corrupted, got this one which is a run to 120, I just expected it to be a lot faster.
This is a run up to 120, again slow start
cbr roll on accell to 120 - YouTube
  #72
Old 09-07-2011, 12:04 PM
TimBucTwo's Avatar
Originally Posted by Shadow
This is the bar, and no-one speaks much sense in here - I've just got here
So, I vote you the designated driver.
Let's hear it for MR MUPPET! Hip Hip HOORAY!
  #73
Old 09-07-2011, 12:18 PM
thrasher572's Avatar
I see what the problem is...no rocket booster, nitrous, or turbo charger. How can you expect to break the sound barrier without at least one of those goodies?
  #74
Old 09-07-2011, 12:41 PM
jarvid's Avatar
Welcome Crew
130, try changing out of second, just joking, gees it's late, just got home, should go to bed.......
  #75
Old 09-07-2011, 01:30 PM
TimBucTwo's Avatar
HP = TORQUE x RPM ÷ 5252
You need to drop a few gears to get the RPM up. Open her up full throttle and shift at red line. Hang on and keep banging gears.
These bikes have 70 ft/lbs of torque.
So you started out at around 2,500 RPM, or 33 HP and then opened it up.
You came up past 6,500 RPM where the engine was making 87 HP.
You need to be starting at 6,500 RPM for you roll-ons to be effective.
Shift to a higher gear at 10,000 RPM, 130 HP max. After 10,000 RPM the valves start to float and other things start to happen and the power curve takes a dive.
It looked like your clutch may have been slipping when coming into power (6,500 RPM) but that may have been due to the video.
  #77
Old 09-07-2011, 06:55 PM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Hey:
I thinks it a good ole Scottish ripper of a wind up. I owned a Silver CBX750F a fast, great handling bike when I lived in Aldershot, Hampshire. It was the Super Sport version of the USA CB750F Nighthawk with a chain drive and bigger carbs. It had Pods and a Micron pipe on it with a Metzeler ME1s with a White Power Shock and GV/ Pro Spring fork kit. It could certainly out handle the CBR1000F, but in no way could it out power it in anyway. If your CBX750F can outrun your CBR1000F, you need to do another compression check and a leak down test on it. Also check that your brakes are not dragging as something is wrong.
Dub
Oh and BTW the White area in the airbox is in all of them, if I recall. Its the harder White ABS shell that the Black ABS box is shaped around to give it a good sealing point for the filter. You have to pull the carb rubbers off, and/or the filter out to see it really well (or break open the airbox).
  #78
Old 09-07-2011, 07:05 PM
Sprock's Avatar
a little more wind in the kilt more like
But were you really expecting award winning results sub 7500 rpm ?
All I can say is ........ No wonder ! LOL ... Do you know where
power band is on these at all ?
Like to see a pic of that white plate with a hole in it
located in the airbox .... ...was someone keeping pet hamsters
in the airbox in the winter or something ?
And yeah Pete I .......did move it in here because from the
get go it has been pretty inconsistent with plenty of gaps
as you can see
Somethings up tho in any event because that was some
wicked slow VID in that clip
Only time I saw something like that was where the riders
left leg was in a cast and he had problems using the gears
with some good throttle.
Liked you other VIDs too Chammy the CBX and stretching the legs of the banger !
And BTW Chammy when setting the valve timing just out of
interest which way did you rotate the motor ? as you say you
are certain it's timed correctly
  #80
Old 09-07-2011, 07:59 PM
Sprock's Avatar
Now yu as yu say ........are just stirring up ch!t ......... all I can say to that is FishStick !
Quick Reply: Restricted Output (warning long post)
