I am out of ideas :icon_cry:
I'll check my coils too, thanks shadow
I balanced my carbs right after I put them back on, but I will check again.
carldalmas
I think will stick to my carbs, I don't want to resort to replacing them just yet, and let me know the shipping costs, Thanks.
carldalmas
Still won't run!!
I made took out the carbs and took out the slide and cleaned it off and it would slide smoothly, but the bike won't even start now. Sometimes it will give a loud ppfftt and shoot smoke out the tailpipe. It I tried to roll start it and it would start with full choke but would die a couple seconds after, and die immediately if I gave it any gas. I checked all plugs and they all give a good spark. I remain stumped.
Guest
Posts: n/a
BTW - the moment you try to open the throttle it lets even more air in and will stall them immediately ...
You have to go over everything to do with the sealing of the carbs , connections and check for vac leaks ..
The next picture shows the carb cleaner straw sticking down an air bleed. This air bleed lifts the piston/needle when the choke is on. Look down this air bleed and move the choke lever. When the choke is on, the air pressure comes through this bleed hole to lift the piston/needle and richen the mixture. With the choke lever open, spray carb cleaner through the bleed. If you spray it when the choke lever is closed, the carb cleaner will come back into your eye.
The last picture shows where the Vaseline goes. The car cleaner straw is pointing to the groove where the rubber O-ring of the diaphragm fits. THIS IS WHERE MOST VACUUM LEAKS OCCUR. Dab a thin layer of Vaseline in this groove before you install the piston/needle/diaphragm. The diaphragm's O-ring should be secured in the groove due to the holding power of the Vaseline. Now put in the spring and secure the cover. Only three more to go.
I did what slowpoke said and it didn't do much, when it did start for a brief moment with full choke, I checked the pipes and #3 and #4 were stone cold, #1 and #2 were warm. So I sprayed some starter fluid in 3 and 4's intakes and it started, but I couldn't find any air leaks. What's next?
