Frustrated Beyond Belief
Hawk,
I intend to wait until I get home before I buy anything. I just wish I had someone who could look at it whilst I am away and give me an idea.
I think it's just sods law that it happened the night before I came to work.
Oh and David you are more than welcome to come around and "help" whenever you want. Maybe we will be able to get out for a blast together this time.
Will you be coming to mine to fit your new rear shock? You know the garage is open whenever you need it mate.
Hawk,
Hi Chippy - yup. please shock attack at yours when Ive got it.
No use me looking for you mate; changing pads, changing fluid, changing levers and that's about my level without the Haynes - more than happy to baby sit/help anyone who does volunteer or ride it to somewhere for you for someone to have a poke if required.
Hawk,
Brighton is a fair old distance away so I understand you not being able to look. I do intend to get some really good miles on the bike this year so you might get a PM with dates when I come down in your direction.
Woof, I just trail the back brake into corners usually which is when I noticed the problem, otherwise I'm with you, mainly use the front brake.
Jarvid, Only been married nearly 5 years to this wife, mind you it is number 4...I must like wedding cake!!
Frustrated - me too
My F-L failed its MOT on rear brake - worn down to the metal - should've checked it obviously. So I rushed home, fitted new pads and returned to get her passed.
Then the rear brake started to play up, so much so that I couldn't even push the bike and riding was impossible too. So I stripped the caliper, fitted new pistons, seals and DOT4. The pistons went in easily and so did the pads with the pistons fully retracted, but now they still seem to bind a little bit. The pads were front ones but as I said they went in easy enough.
Any ideas?
I've also recently fitted new fork oil and seals, a new alternator damper (NOS!), water pump (from breaker), removed, drained and re-fitted the CCT, and new plugs. She now sounds better than she has for years!
Any ideas?
Any ideas?
Any ideas?
1991 Honda CBR1000F AC REAR BRAKE CALIPER | MRCycles
