How To: Replace a throttle cable
:icon_attention:
Well about 3 weeks ago one of my throttle cables snapped. It was the "pull open" cable. I had one ordered and it finally came yesterday so I took some pics of the process because I couldn't really find any to help me out. It was rather easy, didn't have to remove carbs or anything. Being my first bike and all, I've never done anything like this. So if I can do it, anyone on here should be able to do it as well. Step 1: Remove gas tank. Mine is just 2 screws and it lifts up, not sure how easy yours will be. https://sphotos-a.xx.fbcdn.net/hphot...81468474_n.jpg Step 2: Unscrew old cable from throttle. Mine was already snapped so it was easy to get out. https://sphotos-b.xx.fbcdn.net/hphot...18935578_o.jpg disregard the red circle lol You will also need to open up the starter switch box to release cable from throttle handle. https://sphotos-b.xx.fbcdn.net/hphot...88535472_n.jpg Step 3: Remove all hoses that are in your way. Mine was just a couple air hoses. Also remove the air ducts going to carbs, gives you a lil more wiggle room. https://sphotos-b.xx.fbcdn.net/hphot...94629883_n.jpg Step 4: I used a wrench to wedge open throttle to get easier access to throttle cable hold on carbs. https://sphotos-a.xx.fbcdn.net/hphot...24509250_n.jpg Step 5: Use some needle nose pliers to undo old cable. https://sphotos-b.xx.fbcdn.net/hphot...18421813_n.jpg Step 6: Install new cable to throttle handle and reassemble starter box. https://sphotos-b.xx.fbcdn.net/hphot...88535472_n.jpg Step 7: I moved the wrench over to left side of bike to give me room where the cables are actually attached to carbs or throttle body or whatever. https://sphotos-b.xx.fbcdn.net/hphot...06452874_n.jpg Step 8: Route new cable and needle nose again to install. https://sphotos-b.xx.fbcdn.net/hphot...18421813_n.jpg Step 9: Tighten screws on new cable. https://sphotos-b.xx.fbcdn.net/hphot...62054371_n.jpg Step 10: Replace gas tank, and boom! new throttle cables. Here's one with both of the toys, that's Sadie in the background. My gals toy. She thinks she can take the old cbr :P yall know wassup though lol https://sphotos-a.xx.fbcdn.net/hphot...95278530_n.jpg yes I had to use a couple of the pics twice because I didn't get every procedure pictured. Further notice: You may have to play with the throttle while installing to check the slack on the cables. Also it would be smart to lube the cables, which I didn't do... Other than that, it's pretty clean cut and simple. I thought I was gonna have to take off carbs by everything I was reading on the net. Difficulty level: 2 or 3 out of 10. Beginners, don't be nervous. The only problem I found is finding the proper slack in the cable so it will snap back closed. Mine didn't do it when I bought it because the old cable being so tight. So, I'm used to it. It just closes very slowly. After installing, the throttle response is amazing!! Feels like a completely different bike. Made her rev up faster and also the throttle closes a lot faster. I think it wasn't closing all the way before. I'm having to learn her over again. But very glad I did it myself.:icon_toast: If I have forgotten any steps, or anyone wants to add tips or tricks be my guest! I am only an experienced beginner. |
Great write up Wizzle. Its a good one to have in the how to bank for when the time comes to replace one. Cheers.
How exactly did you get the tank off I have mine unscrewed but I'm nervous about detaching the hoses
Turn the petcock to off.
There are 2 screws up on the front, undo those. Next, raise the tank back and undo the hoses. There is a bolt on the rear side of tank that it swivels on, undo that and the tank comes right off. I don't have fairings or a factory seat so not sure about any extra small steps. |
| All times are GMT -5. The time now is 05:03 AM. |
