How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
Open garage with your horn
Old Jul 1, 2008 | 06:32 PM
Tacoma25's Avatar
Default Open garage with your horn
You need to start with a garage door opener. Program your garage, and then de-solder the micro-switch from the curcuit board and install two long length wires instead. You have to use a relay that will be activated by the horn (+) wire because, in my case, the garage opener only runs off of 3 volts. Here are some pics and explanations. The relay is in the left fairing ahead of the regulator.
Old Jul 1, 2008 | 11:22 PM
Vermino's Avatar
Default RE: Open garage with your horn
nice mod
I have a delay garage door openerbut still works on a horn circuit
but seriously, a pretty simplemod to do (i just move every 2 years so not worth it for me)
Old Jul 2, 2008 | 09:56 PM
hopper662's Avatar
Gotta try this sometime when I get bored. Where would I find the relay I need?
Old Jul 3, 2008 | 02:53 AM
mach9's Avatar
Excellent and simple idea to achieve. I did something similar, however, I wired mine into the turn signal cancel button which is actually a ground. I jumped the terminals in the opener with a wire so any time there was power it was transmitting. Then removed the battery, and soldered leads into the battery compartment. i then hooked the positive lead to a switched power source meaning its only hot when the key is on. Now when you press the cancel switch the opener is active because it completes the - side of the circuit. Mind you this only works if the opener has a 12v battery otherwise you need a voltage regulating circuit...which can be done simply with an IC.
Old Jul 3, 2008 | 05:42 PM
Tacoma25's Avatar
You can get a relay from most any auto parts stores. You will usually find them with the fog lights and off road lights. It is just a simple, normally open relay.
Old Jul 4, 2008 | 01:08 AM
hopper662's Avatar
How doI take the 12v power down to 3v?
Old Jul 6, 2008 | 04:35 PM
Tacoma25's Avatar
There is no conversion. If you look at the relay in the crappy schematic I drew, the 12v only passes through the windings at the top where the horn splices in. The 3v passes through the bottom through the switch contacts. Not all garage door openers are 3 volts, many are more, but this is why I used a relay. To put it in simple terms, a relay is justan electrical switch.
Old Jul 9, 2008 | 07:00 PM
Rod38um's Avatar
Hey I just done this modification. I have a genie garage door opener and its remote is key chain sized. Itaped it and the relay together in aneat little package, itfit perfectly up inside the speedo bracket which is only a couple inches from the horn on my 07 1K RR. I simply took the2 wires from the relay, put a double connector on the ends, plugged it into the horn and then plugged the horn wiresonto the extra tabs and its totally hidden, looks factory. Nothing is spliced into, the bike is not modified in any way.
It works great and if I dont want to hear the horn, I just pull one wire from the horn, the relay connection is still made up since it has the double connector and then the horn button only opens the door...no sound...... Love it...thanks for the idea!
Rod
Old Jul 30, 2008 | 01:04 PM
sony1080's Avatar
how many prongs does it need? and what size relay as far as amps or whatever
Old Aug 4, 2008 | 02:52 AM
Blue Fox's Avatar
Retired Moderator
It's a great idea, and was going to do it, until I found this........
Garage door opener key fob. $30 bucks at Lowe's. Programmed one button for my house, another for my ex-roommate's house.
