How to repack exhaust
I stole this from the VFRDISSCUSIONFORUM- thanks to HISPANICSLAMMER
Assuming you have taken off your exhaust.
take a drill and drill out the rivets- if your is riveted. Dont think you can repack exhaust can's that are welded...
"for a welded muffler, you can take it apart and repack it, but you have to be a very skilled welder (if you want it to look good), and you have to have a good cutting tool," Patrick.
[IMG]local://upfiles/1672/98FD9FFDE89D437A849A21A3CD0F1C03.jpg[/IMG]
Once the rivets are punched out you can take off the end caps. The D&D is one solid unit with both end caps welded on, some other units have sews and are easy to get apart. I had to use a rubber mallet and a soft piece of pine to push the end caps out of the tube.
[IMG]local://upfiles/1672/B48DB248FF804337AE6049B2D5B9AE61.jpg[/IMG]
You can see the core is blown out
[IMG]local://upfiles/1672/210F9D9FD83547858A36505476D1CA6B.jpg[/IMG]
I used a utility knife to cut into the old packing, you can see the blown out parts
[IMG]local://upfiles/1672/D02CB0C6A8F147A9AF1269953B1A5098.jpg[/IMG]
Use a wire brush to clean the core
[IMG]local://upfiles/1672/3F9C272B076048E993D669E34C97C981.jpg[/IMG]
I wrapped the core with steel wool to prevent blowouts
[IMG]local://upfiles/1672/1F5A4FC393E947D5A79C22DEC9C19B2C.jpg[/IMG]
I read that wrapping steel wool around the core first prevents the new packing from getting blown out.
here is the fiberglass repack kit
[IMG]local://upfiles/1672/717B3383B3A0478691F252C39111B0B5.jpg[/IMG]
the instruction said to use masking tape
[IMG]local://upfiles/1672/4C671ABE14384FEF8F9EE5DC989A3D17.jpg[/IMG]
Pop Rivet the core back in
I lined up the holes and tapped the core back into the tube, I used some high temp RTV on the end caps to seal them up, I had to pop rivet them on from below cause the pins would fall into the can if I did them from above.
I hammered the rivet caps flat and then cleaned the pipe and polished the whole thing with mothers polish until it shined! I also removed the headers and cleaned it up with a wire cup on my electric polisher. Painted the headers with 1200 degree black ceramic paint. Sealed up the connectors and put in new gaskets.
[IMG]local://upfiles/1672/428D0BE6CF564C968DBE0F468BDB69BC.jpg[/IMG]
