How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
How-To: Rear Spools without Swingarm Modifications
Old Jan 30, 2010 | 12:51 PM
Midlife's Avatar
Excellent idea axsys! I just finished this project and it works like a charm. If anyone else wants to try it, I have a supply of the 1" longer M6 socket head cap screws (I had to buy a box of 50).
PM me if you would like one and I can send it out at cost.
Dan
Old Jan 30, 2010 | 10:09 PM
xjoewhitex's Avatar
How far does this mod bring the wheel from the ground. Having the spool in the center of the wheel would decrease the lift of the stand, does the wheel spin freely?
Old Jan 30, 2010 | 11:16 PM
Midlife's Avatar
I can't say as yet, as I am waiting a bit to buy the rear stand (saving for a Pit Bull). I can't see it being an issue though
Old Feb 3, 2010 | 12:11 AM
axsys's Avatar
I have about 4" under the tire when on my rear T-Rex stand
Old Nov 15, 2010 | 07:45 PM
BeHyper's Avatar
Great write up!
Old Mar 30, 2011 | 11:21 PM
yunebug's Avatar
Thanks for the write up. The tapping took a long time (my first time, too)... good thing I have patience. <:0)
Old May 15, 2011 | 04:03 PM
mark1200's Avatar
rather than drill and tap a rod, i just put a threaded rod all the way through and a nut on each end. works like a charm.
thanks for the great idea.
Old May 17, 2011 | 01:50 PM
cannon929's Avatar
If you have a stand like mine with square shaped "tubes" for insertion of the optional "shelf" or "bobbin" lifters, just remove the lifters, position the stand and insert a suitable rod through the square tubes and hollow axel and then lift. No need for bobbins or nuts...
Old May 18, 2011 | 09:03 PM
mark1200's Avatar
can u post a pic or web addy for your stand so we can see it. i;m not sure ive seen what u are describing.
Thanks.
Old May 19, 2011 | 03:59 PM
cannon929's Avatar
Thanks.
Web addy:
Depotstøtte, bak - Biltema
Norwegian website, but anyway....
Click on "vis større bilde" to enlarge the pic.
On the back side of the square tubes there are set-screws to adust/set the distance between the lifters.
And this stand is cheap, appx 30 euros.
