How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
How to create a signature for the forum
Old Nov 21, 2008 | 03:16 PM
Stephens's Avatar
Default How to create a signature for the forum
Some people have created signatures at the bottom of their posts. If you have ever wanted to know how to do it, I am going to go through the process.
First you can use any program that can create graphics, images and allows you to use text. I use Adobe Photoshop CS2. You can use any version, CS3 is the newest version out there now.
You probably want to put images of your bike in it, so go get your digital camera out, cell phones work but won't give you the best quality photo. So take a photo of your bike. Download it to your computer.
Second, launch Photoshop. Create new document. I recommend the size of 400 or 500 x 100 or 200 pixels. Make sure your resolution is set to 72 dpi. You don't need a high resolution for online viewing.
Create new image
Then you open your image of your bike, copy and paste it into the new file
Then type in the text that you want it to say
Now save the image for web> this is going to be a gif file, gif's are easiest for loading on websites, jpeg's will work also.
Now you need someone to host the image, or you can host it yourself if you have webspace or your own website. Some internet providers give you webspace with you email accounts. Like charter does that for you.
I recommend using www.photobucket.com if you don't have webspace. Its free, all you have to do is set up an account.
Once you have your account, you then upload your image to photobucket.
Now that your image is on the web, you need the code in order for the image to be posted in the forum, they give you a code on the bottom right hand of the screen. Its called the Image Link Code. You will use the last one on the list called the "IMG Code"
Take that code and copy it into your profile in the box that says "signature"
<-That is what the code looks like, except I put a space in between the bracket and the http so you can see what the code looks like.
As you can see by my signature that I have made mine with multiple images, that is done with the animation and layers feature in photoshop. If you want to do some of that here is the link that will tell you how I did it. A bit more time is involved, we must crawl before we walk.
http://www.myjanee.com/tuts/animation/animation.htm
Old Nov 21, 2008 | 06:18 PM
waynecbr600rr's Avatar
Default RE: How to create a signature for the forum
Good right up. I will be using your input to make mine. Thanks.
Old Nov 22, 2008 | 12:56 AM
Stephens's Avatar
Thanks, I was thinking that there are some people out there who wanted one, but never knew how it was done.
Old Nov 22, 2008 | 01:51 AM
PlayfulGod's Avatar
good post, should help alot of folks.
CS4 is the latest tho for photoshop
Old Nov 22, 2008 | 10:12 AM
Stephens's Avatar
Dang, 4 is the lastest, I am out of current events.
Old Dec 3, 2008 | 02:06 AM
NIK600RR's Avatar
ORIGINAL: Stephens
[IMG] http://i165.photobucket.com/albums/u...hens/sig1b.gif[/IMG] <-That is what the code looks like, except I put a space in between the bracket and the http so you can see what the code looks like.
I found out that as soon as you copy paste the code to signature's space you have to turn [IMG] & [/IMG] to [img] & [/img] in order to work.
LJ Harp
Feb 7, 2011 03:41 PM
kinglee86
Jan 17, 2011 12:56 PM
fRacer 954RR
Feb 20, 2007 08:44 PM
Ultimate_17
Feb 13, 2006 08:16 PM
