Hotbodies Blinker + Running Light install
Ok, been thinking what your problem could be. *If* you've wired it just like the diagram, then it would work properly...that is, all other things being the way they should be...ie, if all other wiring is correct. I'd recommend that you go back & carefully inspect each connection, proper wire-to-wire routing, & test again. Be sure to check all your fuses as well. They tend to pop easily during such installs. Good luck.
josh99ta
Mar 19, 2009 04:55 PM
Cun0144
Sep 20, 2008 07:16 PM
ddaren
Jan 17, 2008 07:13 AM
