How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
The Definitive Guide to Installing Vortex Frame Sliders
Old 10-22-2006, 06:17 PM
Default RE: The Definitive Guide to Installing Vortex Frame Sliders
ORIGINAL: kiggy74
Note that the two provided spindles aren't the same size. The smaller spindle and shorter bolt go on the left side of the bike.
Left side of the bike...as in when you're sitting on the bike the left side, right? Just making sure becasue I'm going to be installing my vortex frame sliders on my bike next week sometime.
  #42
Old 12-11-2006, 02:18 PM
SWEET!! This is on my to do list!!
All these write ups are sooo much help to new owner/riders such as myself.
Thanx for puttin in the time to make these!
  #43
Old 12-14-2006, 11:44 PM
Man i wish i was saw this about a week ago. I got it done though..
  #44
Old 12-16-2006, 10:11 PM
BadAzF4i's Avatar
good walk through im glad i saw it cause im about to buy some, i keep putting it off but i should probably just get them or with my luck ill end up droping my bike
  #45
Old 12-17-2006, 02:15 PM
I was wondering if anyone knew if a vortex frame slider for an f4 will fit on an f3.
Good write up
  #46
Old 03-08-2007, 11:58 AM
Hi. I just completed installing Vortex Sliders on my 05 600RR. I used the laser level which worked great. However I used a 1 13/16 hole saw and found that it just fits because of the curveature of the bodywork when in place. I hit the hole dead centre, the slider fits in but there is no gap around the slider. For 600RR installs you may wish to consider 1 7/8 hole saw. Great How To - thanks for the help.
  #47
Old 03-08-2007, 12:30 PM
Jaybird180's Avatar
Is not 1-7/8 the size vortex recommends?
  #48
Old 03-09-2007, 10:51 PM
I did not get any recommendations with the vortex sliders. The original how to on page 1 for a 1000RR used 1 3/4 hole saw. I think because of the different curvature you need 1 7/8 on the 600RR. If Vortex is recommending this - right on. As before mine fit snug with 1 13/16. I was going to try 1 3/4 but decided to go larger - good thing. Again thanks to the original how to.
  #49
Old 03-10-2007, 02:23 PM
Jaybird180's Avatar
My bad. I used 1-3/4 on my F4i and it came out spot on (I just checked). When you drill, Use duct tape around the area where the hole saw makes contact. Drill in a level fashion, parellel to the direction of travel of the mounting bolt. Curvature is irrelevant.
  #50
Old 03-10-2007, 04:54 PM
cwmc29's Avatar
I just installed Vortex sliders on my 2000 F4. Instead of using a laser level, I kinda went old school. I installed the base of the frame slider and then coated it with chalk. I installed the fairing and pushed it against the frame slider base. This gives you a perfect imprint on the foam on the inside of the fairing. I drilled a pilot hole, tapped off the area to be drilled and went to town. I think it worked out ok.
[IMG]local://upfiles/12238/68FB4B6B29EC4BDC949612D2576B6DC7.jpg[/IMG]
[IMG]local://upfiles/12238/F70A6BA2E7F74977ACC564BA33ECCB3F.jpg[/IMG]
Quick Reply: The Definitive Guide to Installing Vortex Frame Sliders
