How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
D.I.Y. LED Peg signals
Old Mar 14, 2006 | 12:14 PM
dragonmaster_91's Avatar
Default RE: D.I.Y. LED Peg signals
Thats a great idea. Thanks for the idea. I might have to try something like that.
Old Mar 14, 2006 | 07:33 PM
1998f3's Avatar
I've got leds placed in my engine bay already, but I'll still try this soon. Maybe this week. Very nice write up man. Very detailed. I only want them for the turn signals, but in red to light up with the tail light.
Old Mar 15, 2006 | 12:36 PM
LikitySplit's Avatar
ORIGINAL: cbrjeeper
I'll be greedy and ask for both
One other question, they aren't wired up as a running light also? Or, brake? They are just for a turn signal, correct? I'm not real eletronics savy. Do the LED's only have one amount of light output? I already have one kit of the LED's you pictured that i was going to use in the engine area.
Tylor
yeah its only for signal!! im sure there's a way to wire them up as are the tail lights but im not sure how!! oh and as for the pics ill post them on here tonight after i get off work!
Old Mar 15, 2006 | 01:27 PM
I wonder if you get a multi color led if you could get it to flash yellow with the blinkers but still manage to get them to turn red when you hit the brakes.
Old Mar 15, 2006 | 02:48 PM
richterat83's Avatar
You could drill 4 holes, and, mount 2 red led's and wire them for the brake, and, 2 yellow, or, whatever color LED's to wire up for your turn signal, but, the wiring would probably be a rats nest.
Tylor
Old Mar 16, 2006 | 05:45 PM
[IMG][/IMG]
[IMG][/IMG]
heres the pics you requested
Old Mar 17, 2006 | 04:01 PM
no1biscuit's Avatar
Looks awesome.
Old Mar 17, 2006 | 04:42 PM
Dang, they look pretty friggen bright. Now, not to jack this thread, but, does anyone know if F3 pegs mount up to an F2? The passenger pegs? Cause, F2's are held by a rod, not the aluminum you can drill out. If they swap, i'm def. doing this mod!!
Tylor
Old Mar 17, 2006 | 09:41 PM
1998f3's Avatar
The F3 pegs wont work. I have an F3, and the only way I could do it is if I drill and mount the leds on the side of the peg, kind of defeating the whole purpose of putting more light in the rear. There is a small piece of aluminum in the way on the pegs. I was going to do it, but I went out anf took a closer look at my pegs.
Old Mar 17, 2006 | 09:43 PM
1998f3's Avatar
If you look in my gallery at the close up of the tail, you can see the small U-shaped pieces welded on there.
