won't start while in gear (clutch in)
Old Jul 11, 2011 | 08:04 PM
OneWheel929's Avatar
Default won't start while in gear (clutch in)
I have only had my cbr for not even a month yet, and noticed about 10 days ago it will not start while in gear (kick stand is up and clutch in) i noticed because i stalled out taking off from a stop light, went to start it back up and had to put it in neutral. I am pretty sure it wasn't this way when i bought it. Any ideas?? its a 2001 929rr
Old Jul 11, 2011 | 08:12 PM
kilgoretrout's Avatar
Administrator - Retired
Probably the clutch switch is going bad or needs adjusted some so it makes contact. Look for a switch at the lever. I wouldn't bypass it altogether if its bad for obvious reasons.
Old Jul 11, 2011 | 11:58 PM
segraves1's Avatar
Another vote for clutch switch. You could temporarily jump the switch to test if it works (though I would rather take the switch off and check for continuity with an ohm meter).
Chris
Old Jul 12, 2011 | 06:34 AM
will look into that, thanks!
supersnake83
May 4, 2022 08:29 AM
CBR-J
Aug 16, 2017 09:19 PM
burbleburble
Oct 3, 2013 08:29 PM
colorofthewave
Sep 18, 2010 09:44 PM
street600
Jul 25, 2008 08:43 PM
