Wiring and open wires
I am rebuilding my 2005 CBR 1000rr and I have new flushmount front turn signals on my bike but I have no wired them in yet, the bike turns over but wont start and I have check the fuel, fuel pump,fuses, and made sure it was in Nuetral, clutch in, made sure the Tilt sensor (i forget the real name for it) was up right. but my main question is and please only give an answer if you know it for a fact not just a hopeful guess. With the front turn signals not connected would that for ANY reason cause the bike to not start? I know it is a long shot but other then that I am starting to run out of ideas on what it could be.
please let me know what you think and if you have a suggestion on what to try if you could be in detail on how you check it that would help a huge amount. thanx everyone
I have taken off the fuel tank a couple of times for different reasons and I have done checks making sure things are hooked up but when I go out tomorrow I will be sure to double check that. even if it is hooked up I thank you for the suggestion of what to double check cause I am out of ideas.
