Windscreen remove and replace
Old Oct 21, 2013 | 08:06 PM
grgaspc's Avatar
New Member
Default Windscreen remove and replace
Wondering if any 2005 CBR junkies have a fix: I took off my windscreen to clean inside and behind the gauge. This windscreen has grommets with inserted thread which stayed on the windscreen and now I am not sure how the windscreen gets re-inserted. The grommets will not feed through the holes in the fairing. I can remove the grommets from the windscreen but it's impossible to feed them through the holes on the fairing from inside. Any recommendations? Thanks
Old Oct 25, 2013 | 10:50 PM
tqaa48's Avatar
those are a bitch to get to. I ended up just taking off my front cowl to get my windscreen back on, they suck.
Old Nov 5, 2013 | 09:03 AM
DonnyBrago's Avatar
What bike is it?
The windscreen on most bikes (incl 2005 f4i) are held on using well nuts (rubber top hats with a brass thread inside). Buy new if the ones on there are knackered.
These are fitted to the windscreen, not the cowl. You put the bolts through the hole in the cowl and into the well nuts fitted to the windscreen (use a nylon washer to save the cowl from damage), as you tighten them the rubber top hat is compressed and acts like a rubber rivet. If you want new, ebay m5 rubber well nuts.
spicymeowmix
Stickies
20
Oct 12, 2012 01:57 AM
csp
Mar 15, 2011 09:33 AM
antatious
F2 Tech
Aug 23, 2010 05:31 PM
espelade
Jul 21, 2010 06:33 PM
