Why doesn't my bike run on the nicest weekend of the year?
Old Apr 21, 2007 | 11:34 AM
SUPERMAN_ON_929RR's Avatar
Default Why doesn't my bike run on the nicest weekend of the year?
So last week I park my bike, everything all good. Yesterday get new can off of IamEli (thanks dude) put it on bike don't start. My fuel pump won't prime. I'm not getting power to but the kill switch seems to work, fuses are good, all I have left to check is the relay. I will probably have done that by the time yins read this. If anybody has a suggestion Superman could use a little help from batman right now. thanks. I know it could be the ecm as well but how do I check?
Old Apr 21, 2007 | 03:59 PM
ss954rr's Avatar
Default RE: Why doesn't my bike run on the nicest weekend of the year?
cant you just use your x-ray vision to check all that stuff without tearing the bike apart??
Old Apr 21, 2007 | 04:19 PM
I ammm ya dick but I can't check for voltage like that.[8D]
Old Apr 22, 2007 | 05:31 AM
marc0011's Avatar
Check the voltage of the battery, make sure it isn't dead. The battery could be too dead to run anything. If that doesn't work, look on a wire diagram and look for point where you can see where you lose power.
Old Apr 22, 2007 | 11:50 AM
Finally, someone with some useful info., thanks but, i'm past that point. Hers an update. I'm getting voltage to the pump, I hooked the pump up to the battery directly and it turns, I checked the fuel cut and the engine stop rely, all the fuses are changed, the kill switch seems to be fine, all grounds are cleaned, bank angle sensor is good. All I have left is to check ECM and Bank Angle again. I can't figure it out and after all that theres not much left.
o2compressor
Oct 26, 2010 10:27 AM
mariof
Jan 27, 2010 04:01 PM
dwarfdwarf
Jul 4, 2009 11:31 AM
plasstik
Mar 17, 2009 07:01 AM
Mwall
Sep 21, 2008 12:45 PM
