WHERE TO FIND FLASHER FOR 03 600RR
Old Nov 11, 2005 | 07:19 AM
MACK_N_HOOD's Avatar
Default WHERE TO FIND FLASHER FOR 03 600RR
I'm Installing a C.A. tail light w/ intergrated turn signals, also with a electroinc flasher so lights dont blink fast..
Can you tell me where the flasher suppose to be ( for turn singals ) located and pic's would be even better...
I know its not in back of the head light housing, nor under the left-side sub frame...
I just cant find ...
Thanks Will
Old Nov 11, 2005 | 01:17 PM
doncollins's Avatar
Retired Administrator
Default RE: WHERE TO FIND FLASHER FOR 03 600RR
I looked over the shop manual for you... the relay is part of the combination meter print board... that's the instrument cluster. The Electronic Flasher they are selling doesn't look like it's used for our bikes. We have to use an inline relay to slow down the flash pattern. Is that what you're talking about?
Old Nov 11, 2005 | 01:24 PM
doncollins's Avatar
If you look at the shop manual page 20-24
here's the text from it, the text in red tells you that the turn signal relay is bad and to replace it, go to page 20-11 for details. Page 20-11 shows you how to remove the printed circuit board from the cluster and replace it.
2. Turn Signal Circuit Inspection
Remove the upper cowl {page 3-9).
Connect the combination meter multi-connector.
Short the White/green and Gray terminals of the
combination multi-connector with a jumper
wire. Turn the ignitions witch ON and check the
turn signal light by turning the turn signal switch
on.
Does the light come on
YES - Faulty turn signal relay; replace the
combination meter print board (page
20-1 1)
Old Nov 12, 2005 | 09:55 PM
doncollins's Avatar
I found this....
http://www.clearalternatives.com/flasher.htm
cbrbear22
Apr 21, 2012 05:14 PM
j.nick66
Feb 22, 2009 02:29 AM
ni$mo350
Dec 16, 2007 01:48 AM
kmazz
Apr 28, 2007 04:24 AM
Krokus_92F2
May 24, 2006 12:32 PM
