Where to Find a DIY on Carb Cleaning?
RE: Where to Find a DIY on Carb Cleaning?
Sorry for linking to a different forum. Its my old one. Still good for tech info.
http://members.stormi.ca/BABBS/viewtopic.php?t=206
after you clean it you might have to do this
http://members.stormi.ca/BABBS/viewtopic.php?t=209
Let me know if you have an more Q.
Good luck
Good luck
Thanks for the links
I found a couple good videos on youtube about carb cleaning.
This is the first part, from here you can click the other3 parts the video:
http://www.youtube.com/watch?v=Aidv4e-KYIM
OK, how do you get the whole carburetor assembly off? Im following the directions in the manual, it says that once you get the top off, disconnect chocke cable, unscrew/loosen the 4 clamps holding 4 carbs to the engine block.
I loosend them and the whole piece will not come out! There is about a 1/8 inch of play when I rock the carb assemply back and forth. Feels like there is a bolt holding it. Cuold it be that varnish has them seized?
ORIGINAL: MarshallY2K
The best way I have found is to slowly work them loose on one side, then a little on the other.
(This is once you are sure you have disconnected all the cables, clamps, etc.)
Just be patient with getting them off...don't get in a hurry an start hammering on them with a ball peen and a screwdriver.!!!
Rock them back and forth, front to back, (up and down) and side to side...using a little spray lube where you can, (WD-40 won't hurt).
Thanks for your help. I didnt want to force anything. I used a pry-bar and gave slight nudges on each side against the frame and was able to get them off. *whew*
Now Im trying to get off the float(s) so i can clean all the varnish off. How do you remove that little pin holding it in there? lol
