What is the torque spec for the countersprocket?
Old 10-12-2005, 07:31 PM
TeeDub's Avatar
Default RE: What is the torque spec for the countersprocket?
Thanks for the link, thats a good write up. I'm just switching the countersprocket, so I shouldn't have to cut the chain should I? Every other bike I've had I could just slip it off the countershaft with enough slack on the rear wheel.
Old 10-12-2005, 08:52 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Nah, just get all the slack you can out of the chain and swap them out. Prolly take you 30 minutes max.
Old 10-13-2005, 01:43 PM
Yeah it's a pretty quick job.
Old 10-16-2005, 06:22 PM
TeeDub's Avatar
Installed the 15t last night. Very easy. The most time consuming part of the job was getting the cover off. The metal guard behind the plate was stuck to it and not allowing the cover to come off. Once I seperated them it was easy. On a side note, I tried using a 14.4v cordless impact gun to remove the nut, which was worthless. I finally just reached over and held the rear brake with my right hand and used a breaker with my left hand, and voila, the nut came right off. Took her for a quick shake down run last night and all seemed well. I couldn't get on it though since the roads were wet.
Old 10-17-2005, 03:58 PM
Tahoe SC's Avatar
then you haven't really felt the difference...and there is a difference...be ready mang!
Old 10-17-2005, 05:48 PM
TeeDub's Avatar
ORIGINAL: chainstretcher
It's officially titled:
Bolt, Special (10MM) P/N 90037-422-003 H/C 1053032
What else ya got?
I think it was actually a 14mm
Old 10-17-2005, 07:13 PM
I think it's a 14mm head but 10mm bolt threads. Honda has a weird way of measuring bolts.
Old 10-20-2005, 07:31 PM
TeeDub's Avatar
ORIGINAL: Tahoe SC
True dat! Going to work today I pulled away from a stop and rolled the throttle on hard at about 5k rpm, front end just starts lifting up! Never did that before.
xcelerated010026
06-03-2009 08:56 PM
egdcbr600rr
08-07-2008 05:39 PM
flash600
04-02-2007 01:27 AM
Ssaba420
06-12-2006 07:54 AM
delta
04-30-2006 12:21 AM
Quick Reply: What is the torque spec for the countersprocket?
