what is this part?
looks to me to be a starter relay.
Assuming that it is you would check it by hooking 12v to one small tab, and ground to the other. It should click. If no click, then its bad. If it does click you measure across the big terminals to make sure there is continuity between them with it powered up, and no continuity when there is no power on the small terminals. If there is always continuity, or never continuity then its bad.
